Side project: Hacking the rx2703h-d 6 axis gyro.
04 Mar 2013 10:13 #7322 by Hexperience
Hello everyone...
I've been really enjoying my "conversion" to Walkera. The transmitters are great quality and of course deviation really unleashes them.
I've been converting a lot of my heli's over to various Walkera RX/Gyro combos and I now have a couple 2702s, a 2618 and a 2703h-d
The 2703h-d flies great, very stable and the self leveling (although very mild) gives me confidence to try new things. (First flips and inverted on this one)
Problems though;
- No ability to reverse servos
- No ability to reverse gyro compensation direction
- Unused servo ports (channels)
- Piro compensation
- Adjustment of settings such as accelerometer vs gryo (yes there is one "balance" pot.
And of course:
- No GUI to set all this up with.
So I started to think, "how hard could it be?"
We have the ability to flash the firmware on to the RX with the update tool.
Anyone interested in helping out with this project?
Cheers
04 Mar 2013 10:32 #7324 by FDR
22 Dec 2013 09:36 #16918 by wesa-76
Can you please help me if you can. My problem is fixed ID canceling. Bind plug wont work. Is there anything to do? I try update witch include canceling fixed ID solved but it doesn`t work.
22 Dec 2013 10:34 - 22 Dec 2013 10:50 #16919 by RandMental
Replied by RandMental on topic Side project: Hacking the rx2703h-d 6 axis gyro.
Try all the Servo ports, one of them usually works.
Edit: also see www.deviationtx.com/forum/6-general-disc...cancel-fixedid#16900
Last edit: 22 Dec 2013 10:50 by RandMental.
02 Feb 2014 23:22 #19758 by Nightshift
Replied by Nightshift on topic Side project: Hacking the rx2703h-d 6 axis gyro.
cHECK IF YOU GOT THE RIGHT BIND PLUG TO CANCEL IT, i WAS HAVING A HARD TIME ONE TIME AND I DIDN'T HAVE THE RIGHT ONE SOME WALKERA BIND PLUG GOT THE JUMPER BETWEEN THE 2 OUTSIDE ONE AND SOME OTHER THE MIDDLE ONE AND A OUTSIDE ONE! CHECK THAT OUT!
26 Apr 2014 12:54 #22728 by Gyori
In nut shell: for reset the signal pin (white) needs to be pulled up to the +5V (red; via the resistor) during the boot-up. Regardless where they put the pins in the "bind plug" in china....
Time to create page: 0.045 seconds
