timer settings
15 Jun 2013 07:39 #10981 by Dakota
timer settings was created by Dakota
Hi, can anyone explain how the timer works? I'm just starting with the deviation and the timer or the countdown timer is running. But it's all time running. I want to count up, when i put the throttle up.(and the countdown down)
15 Jun 2013 08:14 #10982 by FDR
Replied by FDR on topic timer settings
You've probably selected a wrong switch.
You should use the throttle channel (Ch3 for DEVO, Ch1 for DSM) as a switch...
18 Jun 2013 15:05 #11094 by Dakota
Replied by Dakota on topic timer settings
It won`t work .
I have put the channel ( Nr. 3 ) into the timer. It will not start ??!! what do you mean "as a switch" ?
18 Jun 2013 15:21 #11096 by FDR
There is a spinbox on the timer config labelled as "Switch".
You should select "Ch3" into it to start the timer with the throttle channel in case of the DEVO protocol.
19 Jun 2013 19:39 #11135 by Dakota
It`s done ! my mistake was that i have not correct calibrated my sticks. So all the time the timer is running. Now it`s working.
20 Jun 2013 02:59 #11152 by notyet
Replied by notyet on topic timer settings
On a related note- how do you reset the timer?
I don't see anything in standard gui.
20 Jun 2013 03:01 #11153 by Kdean
Replied by Kdean on topic timer settings
If nothing is selected to reset in the settings, then a long press on the box will do it. Tap to start, tap to stop, long press to reset.
20 Jun 2013 03:52 #11154 by vlad_vy
Replied by vlad_vy on topic timer settings
At Devo 8s long press 'EXT' button also reset the timer.
01 Jul 2013 05:21 #11659 by SmokeNGun
Replied by SmokeNGun on topic timer settings
Question. First I have not done the upgrade of the deviation software I do have the Devo 8s and the 7e. What I like about the timer on the 7e is that for me its loud enough to hear plus it vibrates. On the 8s the audio is to loud for me and it does not vibrate.
Now with the upgraded software does any of this change ?
01 Jul 2013 05:45 #11660 by Kdean
The 8s wont be able to vibrate, but you can adjust the buzzer volume in deviation.
01 Jul 2013 05:58 #11661 by Kdean
Welcom SG, good to see you here. Have fun.
05 Jul 2013 13:59 #11948 by notyet
Log pressing EXT doesn't seem to reset the temporary timer on the Devo 10.
Is there a way other than turning the unit off and on or am I missing it?
Time to create page: 1.015 seconds
