timer settings
- Dakota
15 Jun 2013 07:39 #10981
by Dakota
timer settings was created by Dakota
Hi, can anyone explain how the timer works? I'm just starting with the deviation and the timer or the countdown timer is running. But it's all time running. I want to count up, when i put the throttle up.(and the countdown down)
15 Jun 2013 08:14 #10982
Replied by FDR on topic timer settings
You've probably selected a wrong switch.
You should use the throttle channel (Ch3 for DEVO, Ch1 for DSM) as a switch...
- Dakota
18 Jun 2013 15:05 #11094
by Dakota
Replied by Dakota on topic timer settings
It won`t work .
I have put the channel ( Nr. 3 ) into the timer. It will not start ??!! what do you mean "as a switch" ?
18 Jun 2013 15:21 #11096
There is a spinbox on the timer config labelled as "Switch".
You should select "Ch3" into it to start the timer with the throttle channel in case of the DEVO protocol.
- Dakota
19 Jun 2013 19:39 #11135
by Dakota
It`s done ! my mistake was that i have not correct calibrated my sticks. So all the time the timer is running. Now it`s working.
- notyet
20 Jun 2013 02:59 #11152
by notyet
Replied by notyet on topic timer settings
On a related note- how do you reset the timer?
I don't see anything in standard gui.
- Kdean
20 Jun 2013 03:01 #11153
by Kdean
Replied by Kdean on topic timer settings
If nothing is selected to reset in the settings, then a long press on the box will do it. Tap to start, tap to stop, long press to reset.
20 Jun 2013 03:52 #11154
Replied by vlad_vy on topic timer settings
At Devo 8s long press 'EXT' button also reset the timer.
- SmokeNGun
01 Jul 2013 05:21 #11659
by SmokeNGun
Replied by SmokeNGun on topic timer settings
Question. First I have not done the upgrade of the deviation software I do have the Devo 8s and the 7e. What I like about the timer on the 7e is that for me its loud enough to hear plus it vibrates. On the 8s the audio is to loud for me and it does not vibrate.
Now with the upgraded software does any of this change ?
- Kdean
01 Jul 2013 05:45 #11660
by Kdean
The 8s wont be able to vibrate, but you can adjust the buzzer volume in deviation.
- Kdean
01 Jul 2013 05:58 #11661
by Kdean
Welcom SG, good to see you here. Have fun.
- notyet
05 Jul 2013 13:59 #11948
by notyet
Log pressing EXT doesn't seem to reset the temporary timer on the Devo 10.
Is there a way other than turning the unit off and on or am I missing it?
Time to create page: 0.218 seconds
- timer settings
