Devo 7e v4.0.1 and Hobsan X4 H107L Binding issue
- droople
19 Jan 2014 07:09 #18665
by droople
Devo 7e v4.0.1 and Hobsan X4 H107L Binding issue was created by droople
Hello
I got my Devo 7e today, and installed Deviation 4.0.1 and added the V911 TX radio module.
I am trying to bind my Devo 7e and Hobsan X4 107L, but it shows binging and never get banded.
I'm a noob on the transmitter, I'm not sure are there any model/protocol file for H107L I could download.
Thank you in advance
- John-Boy
19 Jan 2014 07:21 - 19 Jan 2014 07:25 #18666
by John-Boy
Replied by John-Boy on topic Devo 7e v4.0.1 and Hobsan X4 H107L Binding issue
Don't forget to edit the tx.ini file and enable the a7105 module. Then look here for more ideas:
www.deviationtx.com/forum/6-general-disc...-bind-problems#18402
Here's a Hubsan config:
www.deviationtx.com/forum/model-configs/1227-hubsan-x4-config
Good Luck...
Good Luck...
Last edit: 19 Jan 2014 07:25 by John-Boy.
- droople
19 Jan 2014 09:47 #18669
by droople
thank you John, I checked the both threads and loaded the config,but still no luck
here is my tx
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=A14
has_pa-nrf24l01=1
Replied by droople on topic Devo 7e v4.0.1 and Hobsan X4 H107L Binding issue
John-Boy wrote: Don't forget to edit the tx.ini file and enable the a7105 module. Then look here for more ideas:
Good Luck...
here is my tx
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=A14
has_pa-nrf24l01=1
- John-Boy
19 Jan 2014 10:19 - 19 Jan 2014 11:55 #18672
by John-Boy
Are you sure of which data line you used?
Try this:
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A14
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=A13
has_pa-nrf24l01=1
Later....
Try this:
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A14
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=A13
has_pa-nrf24l01=1
Later....
Last edit: 19 Jan 2014 11:55 by John-Boy.
- Daryoon
20 Jan 2014 05:37 - 20 Jan 2014 05:39 #18756
by Daryoon
Replied by Daryoon on topic Devo 7e v4.0.1 and Hobsan X4 H107L Binding issue
Yes, it's important to know which location you soldered the NRF24L01 module to.
The TMS or the TCK point.
TMS = A13
TCK = A14
Read my post here and pay attention towards the end where I talk about that.
www.hacksmods.com/2013/05/nrf24l01-devo7e-pinout/
TMS = A13
TCK = A14
Last edit: 20 Jan 2014 05:39 by Daryoon.
- droople
14 Mar 2014 07:20 #21535
by droople
Thank you John
I found the reason is that I did put a7105 chip on the board
Now it was fixed.
But the Aile controls the rolling leftward and rightward, and Elev controls the forward and backward. It's the opposite way I want.
Could you tell me how to swap the control between Aile and Elev?
Now it was fixed.
- John-Boy
14 Mar 2014 12:46 #21539
by John-Boy
I don't know what to say.... If you switch the functions of the Ailerons and Elevator you won't be following any control scheme I have heard of.
Maybe you want to try it as is so you will be ready for other aircraft that follow standard control layouts?
If not, follow the directions of the Advanced GUI. Select Channel #1 and change its source from Aileron to Elevator. Then change Channel #2 source to Aileron.
Good luck?
Good luck?
- droople
14 Mar 2014 13:00 #21540
by droople
sorry, I'm confused with Aile and Elev as English is not my first language.
What happened is the Elev controls the rolling leftward and rightward, and Aile controls the forward and backward. And I want to correct it.
- John-Boy
14 Mar 2014 14:12 - 14 Mar 2014 14:12 #21546
by John-Boy
I don't think I can help more.... Use the translator here:
Google Translation of Documents
To download the manual in the language you need.
Last edit: 14 Mar 2014 14:12 by John-Boy.
- droople
19 Mar 2014 06:03 #21659
by droople
I swap the channel according the manual, I'm not sure why the default config is wrong.
- Devo 7e v4.0.1 and Hobsan X4 H107L Binding issue
