Just got the Devo 10, any tips before I begin?
12 Feb 2014 14:18 #20190 by rcminiman
Hi folks,
Cant wait to get the Devo 10 working.
I will be installing the software on a non internet connected laptop. I have got the Devo defuse and Deviation software on my usb stick ready for trying tonight. Ive also printed out the Deviation manual, and will have my tablet standing by for web searches or post here should I encounter any difficulties.
Will I run into any difficulties if I dont have the web connected on the laptop?
Im pretty nervous about this, any assistance would be appreciated.
I will also need setup files for Nano cpx please if possible? How do I work them, as they save as a txt file to my usb stick when I right click and "save as".
12 Feb 2014 14:21 #20191 by WheresWaldo
Replied by WheresWaldo on topic Just got the Devo 10, any tips before I begin?
The model.ini files are linux text files, if Save as... saves them with a txt extention just remove the extension and make sure it's named modelxx.ini where xx is a number from 01 to 30.
12 Feb 2014 14:59 #20195 by rcminiman
Replied by rcminiman on topic Just got the Devo 10, any tips before I begin?
Cheers Waldo. That makes sense, thanks.
12 Feb 2014 22:15 #20208 by rcminiman
Yipee, its working!
I cant remember if it will work with my Nine Eagles 100D? Its got a J6 tx. Ive not tried yet.
Have programmed and flown a few micros already, including my ncpx. This should make a lot of difference using only one tx for all my helis.
Will get my 450's programmed at the weekend.
Nobody got a single servo swash program for a trex 450 running CopterX fbl gyro?
Well happy here so I am!!!
Many thanks to all of the programming developers involved in Deviation!!
12 Feb 2014 22:21 #20209 by billmester
Replied by billmester on topic Just got the Devo 10, any tips before I begin?
check the play of the mechanics. Please go and check the topic here:
www.deviationtx.com/forum/6-general-disc...tick-centering-issue
Will make a MASSIVE change.
Cheers,bm
13 Feb 2014 14:50 #20234 by rcminiman
Hi Bill, checked mine and its all fine. Thanks for the heads-up though, appreciate it. Was the pot shaft sliding in its grip I presume?
Time to create page: 0.682 seconds
