How to set a sound alarm for an actived switch
- lcn
15 Apr 2014 17:49 - 15 Apr 2014 17:49 #22422
by lcn
How to set a sound alarm for an actived switch was created by lcn
Hello
I would like to get a sound alarm when a switch is set to ON.
Did not find how to do this.
Thanks for your help,
Last edit: 15 Apr 2014 17:49 by lcn.
15 Apr 2014 18:25 #22424
Replied by FDR on topic How to set a sound alarm for an actived switch
No how, but what would be the purpose of that?
- lcn
15 Apr 2014 18:56 - 16 Apr 2014 05:16 #22425
by lcn
Replied by lcn on topic How to set a sound alarm for an actived switch
It will be when the multirotor fail safe " back to home" switch is engaged .
Because this will radically change the multirotor direction so I would like the Devo warns this.
Is it possible to do it ?
Last edit: 16 Apr 2014 05:16 by lcn.
- esklarski
15 Apr 2014 20:31 - 15 Apr 2014 20:34 #22430
by esklarski
Replied by esklarski on topic How to set a sound alarm for an actived switch
I don't have an emulator or tx handy, but I feel this should be possible in a manner.
Make a virtual channel, max/min around the switch you want
Make a timer, 1sec countdown, on when switched on, reset with switch off position.
If you set the count up alarm to 1 sec intervals you'll get a beep every second once the switch is thrown. Set to 5, every 5 seconds. It will beep continuously though.
I'll try it out later today.
Last edit: 15 Apr 2014 20:34 by esklarski. Reason: spelling and clarity
- esklarski
15 Apr 2014 21:36 #22432
by esklarski
Scratch that, easy to do. Assuming Mix2 as your return to home:
timer4 - countdown
switch - Mix2
reset - !Mix2
start - 00:00
in the tx config menu under timer settings set 'Timeup interval' to whatever (x) and you'll get a beep when the switch is flipped to Mix2 and beeps every 'x' seconds after.
timer4 - countdown
switch - Mix2
reset - !Mix2
start - 00:00
- lcn
16 Apr 2014 21:40 #22483
by lcn
Hello
Many thanks,
This solution works, but in the config menu i can't get 'Timeup interval' less than 5s.
It there a way to decrease it to 2s ?
Many thanks,
- esklarski
17 Apr 2014 16:05 #22507
by esklarski
What radio + deviation version are you using? My 6s lets me choose: off, and 1-60 in 1sec increments.
- lcn
17 Apr 2014 20:23 #22524
by lcn
I've a Devo 12s
Time to create page: 0.428 seconds
- How to set a sound alarm for an actived switch
