Possible to "mix" down elevator with up throttle?
- SLMcc
04 Dec 2014 20:46 #26767
by SLMcc
Possible to "mix" down elevator with up throttle? was created by SLMcc
Hey all, I just got my first trainer plane. I had a very experienced pilot fly it and he said it really needs some down elevator mixed in the throttle above about 65% stick. Is this something Deviation can do? I tried searching but couldn't find anything. Maybe "mix" isn't the right term for what I want to do?
- aMax
04 Dec 2014 21:24 - 04 Dec 2014 21:29 #26768
by aMax
Replied by aMax on topic Possible to "mix" down elevator with up throttle?
Don´t trust him.
Test if Elevator - Wing - Dihedral is correct and /or the angle of thrust for
the engine.
the engine.
Last edit: 04 Dec 2014 21:29 by aMax.
- SLMcc
04 Dec 2014 21:38 #26769
by SLMcc
Replied by SLMcc on topic Possible to "mix" down elevator with up throttle?
I'd still like to know if this is possible with Deviation or if I'd need a new Tx.
Thanks for your thoughts.
- aMax
04 Dec 2014 21:41 - 04 Dec 2014 21:44 #26770
by aMax
Simply, yes.
With a mixercurve. Thrust > elevator.........
How much it would be, must be testet while flying.
Use the trimm at certain speed/throttle for that and remember the value.
Then setup a mixer.
Then setup a mixer.
Last edit: 04 Dec 2014 21:44 by aMax.
- kreidler
04 Dec 2014 21:54 #26771
by kreidler
Replied by kreidler on topic Possible to "mix" down elevator with up throttle?
With Deviation you do have one of the most powerful Tx software on your transmitter.
I would recommend to read deviationtx.com/forum/how-to/2987-how-to...-or-complex-template . Could be confusing but it's worth.
You could you also use virtual channels to perform this job but the simple way would be like that:
- Change ELE channel to Complex template (manual 8.2)
- Normally the origin setup will be used for page 1.
- Add a new mixer by adding a second page
- On page 2 Mux type to be 'add'.
- On page 2 source should be THR or !THR for reverse mixing
- On page 2 for the scale start with 5 percent.
- On page 2 apply an offset of e.g. 65
- If needed define a switch to make possible to switch off this mixer.
- SLMcc
05 Dec 2014 00:30 - 05 Dec 2014 00:31 #26780
by SLMcc
Thanks guys. I appreciate the help. I've been using Deviation for awhile but just micro helis and I just grab a .INI from someone here. Setting up for an airplane is completely new and I doesn't seem many people here fly planes.
Edit: BTW, is "mix" the correct term for this? Thanks!
Last edit: 05 Dec 2014 00:31 by SLMcc.
- kreidler
07 Dec 2014 09:11 #26836
by kreidler
In my opinion 'compensation' would be more correct but I think everybody understood 'mix down'.
BTW: I do not fly heli
- SLMcc
08 Dec 2014 18:35 #26854
by SLMcc
Thanks! This is my only plane experience.
Time to create page: 0.289 seconds
- Possible to "mix" down elevator with up throttle?
