Possible to "mix" down elevator with up throttle?
04 Dec 2014 20:46 #26767 by SLMcc
Hey all, I just got my first trainer plane. I had a very experienced pilot fly it and he said it really needs some down elevator mixed in the throttle above about 65% stick. Is this something Deviation can do? I tried searching but couldn't find anything. Maybe "mix" isn't the right term for what I want to do?
04 Dec 2014 21:24 - 04 Dec 2014 21:29 #26768 by aMax
Don´t trust him.
Test if Elevator - Wing - Dihedral is correct and /or the angle of thrust for
the engine.
Last edit: 04 Dec 2014 21:29 by aMax.
04 Dec 2014 21:38 #26769 by SLMcc
I'd still like to know if this is possible with Deviation or if I'd need a new Tx.
Thanks for your thoughts.
04 Dec 2014 21:41 - 04 Dec 2014 21:44 #26770 by aMax
Simply, yes.
With a mixercurve. Thrust > elevator.........
How much it would be, must be testet while flying.
Use the trimm at certain speed/throttle for that and remember the value.
Then setup a mixer.
Last edit: 04 Dec 2014 21:44 by aMax.
04 Dec 2014 21:54 #26771 by kreidler
With Deviation you do have one of the most powerful Tx software on your transmitter.
I would recommend to read deviationtx.com/forum/how-to/2987-how-to...-or-complex-template . Could be confusing but it's worth.
You could you also use virtual channels to perform this job but the simple way would be like that:
  • Change ELE channel to Complex template (manual 8.2)
  • Normally the origin setup will be used for page 1.
  • Add a new mixer by adding a second page
  • On page 2 Mux type to be 'add'.
  • On page 2 source should be THR or !THR for reverse mixing
  • On page 2 for the scale start with 5 percent.
  • On page 2 apply an offset of e.g. 65
  • If needed define a switch to make possible to switch off this mixer.
05 Dec 2014 00:30 - 05 Dec 2014 00:31 #26780 by SLMcc
Thanks guys. I appreciate the help. I've been using Deviation for awhile but just micro helis and I just grab a .INI from someone here. Setting up for an airplane is completely new and I doesn't seem many people here fly planes.
Edit: BTW, is "mix" the correct term for this? Thanks!
Last edit: 05 Dec 2014 00:31 by SLMcc.
07 Dec 2014 09:11 #26836 by kreidler
In my opinion 'compensation' would be more correct but I think everybody understood 'mix down'.
BTW: I do not fly heli ;)
08 Dec 2014 18:35 #26854 by SLMcc
Thanks! This is my only plane experience.
Time to create page: 0.083 seconds
