dual aileron and dual elevator for delta wing
- krupukbwg
31 Mar 2015 05:34 #30519
by krupukbwg
dual aileron and dual elevator for delta wing was created by krupukbwg
Hello everyone,
Right now, i have build this :
This is, delta swapable from flite test.
And this my transmitter :
Devo 7e with deviation 1.7 firmware.
And also, this my electronics hardware :
And my question is, what should i do to make all of this to become dual aileron and dual elevator.
I thank you in advance and sorry if my words are not pleasing, and sorry once again due to my bad english.
Mawan
Mawan
- krupukbwg
31 Mar 2015 05:38 #30521
by krupukbwg
Replied by krupukbwg on topic dual aileron and dual elevator for delta wing
31 Mar 2015 20:56 #30578
Replied by mwm on topic dual aileron and dual elevator for delta wing
1) Upgrade to devation 4.0.1. 1.7 is ancient. Are you sure it's deviation, and not devention?
2) Check out the 6Ch plane predefined mixes . If you're not clear about which one to use, ask for help on that thread.
- krupukbwg
01 Apr 2015 02:01 #30597
by krupukbwg
hi MWM,
yes, thats right my deviation is 4.0.1. not 1.7 , 1.7 is DevoDfuSe_v1.7_Setup, oke i will check the link " 6Ch plane predefined mixes" and i will inform about the progress.
mwm wrote: 1) Upgrade to devation 4.0.1. 1.7 is ancient. Are you sure it's deviation, and not devention?
hi MWM,
- trawlins
10 May 2015 02:22 #32324
by trawlins
Replied by trawlins on topic dual aileron and dual elevator for delta wing
- Cereal_Killer
10 May 2015 17:06 #32356
by Cereal_Killer
Replied by Cereal_Killer on topic dual aileron and dual elevator for delta wing
deviationtx.com/forum/model-requests/427...von-mizer-for-a-v911
I just had this thread getting an elevon mix setup, my file absolutely will not work for you however I wouldn't mind the practice of setting up another mix, just to gain the personal experience.
If I can do it for you post your starting .ini, or at the least post which channel is which and all the pertinate info and I'll do it for you.
Time to create page: 0.115 seconds
- dual aileron and dual elevator for delta wing
