dual aileron and dual elevator for delta wing
31 Mar 2015 05:34 #30519 by krupukbwg
Hello everyone,
Right now, i have build this :
This is, delta swapable from flite test.
And this my transmitter :
Devo 7e with deviation 1.7 firmware.
And also, this my electronics hardware :
And my question is, what should i do to make all of this to become dual aileron and dual elevator.
I thank you in advance and sorry if my words are not pleasing, and sorry once again due to my bad english. :lol:
Mawan
31 Mar 2015 05:38 #30521 by krupukbwg
Replied by krupukbwg on topic dual aileron and dual elevator for delta wing
This is delta swapable from flite test.
This is my devo 7e with deviation 1.7 firmware.
And this is are other electronic hardware.
31 Mar 2015 20:56 #30578 by mwm
1) Upgrade to devation 4.0.1. 1.7 is ancient. Are you sure it's deviation, and not devention?
2) Check out the 6Ch plane predefined mixes . If you're not clear about which one to use, ask for help on that thread.
01 Apr 2015 02:01 #30597 by krupukbwg
mwm wrote: 1) Upgrade to devation 4.0.1. 1.7 is ancient. Are you sure it's deviation, and not devention?
hi MWM,
yes, thats right my deviation is 4.0.1. not 1.7 , 1.7 is DevoDfuSe_v1.7_Setup, oke i will check the link " 6Ch plane predefined mixes" and i will inform about the progress.
10 May 2015 02:22 #32324 by trawlins
10 May 2015 17:06 #32356 by Cereal_Killer
Replied by Cereal_Killer on topic dual aileron and dual elevator for delta wing
deviationtx.com/forum/model-requests/427...von-mizer-for-a-v911
I just had this thread getting an elevon mix setup, my file absolutely will not work for you however I wouldn't mind the practice of setting up another mix, just to gain the personal experience.
If I can do it for you post your starting .ini, or at the least post which channel is which and all the pertinate info and I'll do it for you.
Time to create page: 0.596 seconds
