Channel 1 should -100?
07 Jun 2015 13:22 #33583 by yogi b
Replied by yogi b on topic Channel 1 should -100?
mwm wrote:
yogi b wrote: safetysw=Virt1
failsafe=-100
safetyval=-100
template=simple
[mixer]
src=THR
dest=Ch1
This is the safety switch feature, which is a per-channel feature allowing you to force a channel output to a specific value with a switch, ignoring all the programming. The safety feature discussed above is a per-model feature, allowing you to specify for each channel a value for which it's safe to connect to the model. The former is for things like throttle hold, but gets used for things like Panic switches as well. The latter is to warn you about channel values that could cause the model to do something unsafe - like spin the props or take off - if you connected to it with them set that way.
Thank you
i see, totally different thing
i compensated instead of corrected
changing .ini file now
Thanks again
07 Jun 2015 16:28 #33588 by yogi b
and of course it works
thanks again
Time to create page: 0.624 seconds
