BIG plans for my Devo 10
11 Jul 2015 12:44 #35331 by niteliter
BIG plans for my Devo 10 was created by niteliter
I have 3 Blade 400's ( its a nostalgia thing),an Esky CPV2,2 CX20's,and just ordered a Walkera V450D03,ALL of which I plan to run from this Devo 10,I am finding its not at all a "plug and play" thing,my best option would be to switch out alll the RX's for Devo Rx's,thats my quess,next,I was told that a DEVO 10 needs to have a 10 or more channel RX or more to work?Im NOT seeing that.
Also in the near future I want to hook up the WK-CTL01-D to my HIGH climbing CX20,but when i opened the box,there were no GPS or 3 pin plugs?Guess I be doing alot of info searching........
11 Jul 2015 16:35 #35338 by Thomas.Heiss
Replied by Thomas.Heiss on topic BIG plans for my Devo 10
The Blade 400 gyros are not that top, aren't they?
Blade 4503D already uses MEMS G210. It is not top notch either.
Your V450 will use the Walkera FBL.
How good are the cyclic + tail servos? Do you not have to exchange them with new MG ones?
Do you really think that the Walkera FBL can be compared to Spirit System FBL, BeastX Plus/Pro, V-Stabi NEO, Brain and kind of modern FBL systems? Rescue, Self-Leveling...auto-pitch on (3d) rescue...
I can't tell... I am not flying it.
The Blade 400 are paddle, right?
120 CCPM heli will work with DeviationTX of course. I am using it on Blade 450 3D.
But you may want to check out a Spartan Gyro?!
Personally I do not like 2 or 2 channel DSSS only systems.
I am more into Spektrum DSMx with telemetry flightlog.
I have a post about it (AR8000, TM1000) in the DSM telemetry support thread.
Of course you can set the model to 6-7CH only.
So I could bind with Spektrum AR600, AR6210.
You do NOT only have to use 10++ channel receivers.
You can set the channels up to 12CH (if you need).
You can also check out the FrSky (including telemetry) CC2500 threads...
Greetings
Thomas
11 Jul 2015 17:06 #35339 by niteliter
Replied by niteliter on topic BIG plans for my Devo 10
1-No the 400 Gyro isnt all that it should be,overall on a scale of 1 to 20,I would have to give the Blade 400 a 7-1/2,but tats just my take.,Everyone I know that flies the 400 says I should have gotten away from it,and yes tey are right,but there is a challenge here,to make them all fly well,its getting to be a time consuming deal.thats why I thought I would give the V450 a try.
Im not sure how the V450 is,I didnt get it yet,but from what I have seen on youtube,once I get it setup RIGHT with the Devo 10,I hope to be spending more time flying amd less time fixing.
And yes the 400 has paddles.
Most of my flying time is with one of my CX20's,I havent flown a copter in 7 yrs,but I am now getting them air ready,but thats hard when u work 56 hours aweek.........
12 Jul 2015 00:35 #35346 by Zaphod
Replied by Zaphod on topic BIG plans for my Devo 10
The V450 D01 and D03 are fine birds. The servos don't need replacing at all. (I have both and have crashed both).
As for comparing their FBL / RX unit - I've converted my Blade 400 to FBL and after trying a few controllers settled on the Walkera RX2703V-D purely because its plug and play. No settings to play around with. Tail hold is great. Gyros are adjustable on the RX.
Out of the box my D03 was ready to fly. No adjustments needed. I've flown in extremely hot weather and windy weather and its shown no signs of faltering. Nearing 45 flights on it now.
I fly my birds with a Devo 10, Deviation, CC2500 module and NRF24L module. Protocols - DSM2, HiSky, V2x2, Skyartec and Walkera.
12 Jul 2015 01:02 #35347 by niteliter
Im very new to this Devo venture,lots to learn,and try,
I did order from Banggood a FBL head I want to try on one of my 400's,I need to learn more about these so called "Modules",but in time.........hopefully before I get over this hobby.......
and that name "Zaphod" rings a bell..........
12 Jul 2015 01:10 #35348 by niteliter
12 Jul 2015 02:06 - 12 Jul 2015 02:09 #35350 by RedSleds
Replied by RedSleds on topic BIG plans for my Devo 10
niteliter wrote: are these those modules?
www.ebay.com/itm/2-pcs-A7105-2-4G-Wirele...&hash=item27ee7db6d6
No, that is a listing for two(2) A7105 modules, and at 0dBm transmitting is a low power one at that. No PA or LNA on that particular module.
Ebay sellers are notorious for listing multiple different modules in the listing subject line other than those that are actually being sold in that particular listing. They do this to get more search hits for them. A crappy way to do business, if you ask me. You need to carefully read them all the way through to be certain what you are really buying!
Last edit: 12 Jul 2015 02:09 by RedSleds.
12 Jul 2015 02:22 #35351 by grnd flyr
Replied by grnd flyr on topic BIG plans for my Devo 10
niteliter, fwiw... these are the two modules I ordered through eBay:
A7105-500m 2.4G Wireless Transceiver Antenna
www.ebay.com/itm/261417337765
2.4G 22dBm 100mW nRF24L01P+PA+LNA Wireless Transmission Module Shield Case
www.ebay.com/itm/331417904702
...then re-ordered a week or so again... seems my better half & son want their own deviated 7E too... :)
12 Jul 2015 04:12 #35355 by Zaphod
This is the head I used on my Blade 400. Perfect fit with no modifications were needed.
www.banggood.com/Tarot-450-DFC-Split-Loc...802503-p-927388.html
12 Jul 2015 10:39 #35365 by niteliter
grnd flyr wrote: niteliter, fwiw... these are the two modules I ordered through eBay:
I have added them to my Ebay watch list.
thats pretty cool that you have a son AND a better 1/2 that fly too,I can see a basement FULL of RC stuff in THAT house.......(sorry we had basements in New York,but N OT here in Virginia)
And as far as the FBL head,I ordered one from Banggood,and NOW im sure it was YOU that sent me the link in RCGoups.com
Thanks....
13 Jul 2015 03:11 #35392 by Zaphod
Yep that's me :)
My B400 has rapidly become my FBL controller test bird. Kbar, X303X and now RX2703V-D. Will be trying others as well ;)
13 Jul 2015 10:01 #35401 by niteliter
I use one of the 400's.and one of the CX20's for experiments.........
26 Jul 2015 14:52 #36049 by niteliter
NO modifications needed..............hmmmmmmm
Ok i got the part ,it seems that the main shaft that came with it is shorter,did you use the shorter main shaft,or the OEM main shaft?
annndddd,will I need to add any thing else?such as compatible gyro,and or RX?
26 Jul 2015 22:20 #36092 by Zaphod
I used the main shaft on the B400 - not the one that came with the head. Head fitted it perfectly.
Once the head is fitted you'll need a fbl controller. I used the B400 rx and right now a K-bar fbl. Or you can use a combined rx/fbl unit like the Walkera RX2703V-D or X303V.
26 Jul 2015 23:53 #36101 by niteliter
How do I keep getting into these "Buy this,then to make it work you will need to buy that,then to control it ,you need to order them"???
Sloooowwwlyy ,but sooner or later..............
lol,lovin it.........
beets the heck outs getting drunk........
Time to create page: 1.098 seconds
