How to set-up a Devo 7E
27 Mar 2016 22:56 #45304 by Sero
Replied by Sero on topic How to set-up a Devo 7E
Just to clarify, what receivers are you trying to bind, the link you posted before is for a satellite, not a receiver.
If you are indeed using a satellite, what sort of hardware are you using that satellite with, i.e. a quadcopter or such.
27 Mar 2016 23:12 #45305 by Deal57
Replied by Deal57 on topic How to set-up a Devo 7E
So, to sum it up, you've installed deviation, calibrated, and created a model using DSM2 and 6 channels for your Orangerx 6 channel DSM2 receiver. When you try to bind you get no indication of a bind.
The thread at deviationtx.com/forum/7-development/5406...ngerx-r720x-v2#43128 discusses two alternatives; turn off telemetry (if it is on), or add channels (although the thread discusses SBus and CCPM connections, too. But it may be worth a look.
If every one of your receivers got 12v, then the fact that you get lights may not mean they aren't damaged in some way. It's impossible to tell from here.
You can also try an earlier nightly. I dint know of any changes to the DSM2 protocol, but I suppose I'd try it if it were me,
28 Mar 2016 14:20 #45335 by roineust
Replied by roineust on topic How to set-up a Devo 7E
I am trying to switch the latest nightly build with the 2014 4.01 formal version - but the Deviation up-loader will accept only the debug version, why is it so?
Time to create page: 0.990 seconds
