I cannot update my devo 7e with Devention DfuSe
- choban
29 Jun 2016 17:21 #51178
by choban
I cannot update my devo 7e with Devention DfuSe was created by choban
I am trying to update my Devo 7e to run Devention firmware. I have installed the Defuse USB software, this looks like it worked. I plug my USB cable into my Devo 7e transmitter and into my computer. I press the EXT botton on the transmitter and turn it on, it goes into Program Update mode. I then go to select the upgrade botton in the Defuse USB software and the upgrade botton is grayed out, you cannot select it. I have reinstalled the software and rebooted my PC and still no connection. My PC is running windows 10, and I am using the latest version of Defuse software 2.?? and Devention 5.0 firmware. According to all the post this should be a no brainer. Would really appreciate some help.
- D_an_W
29 Jun 2016 18:58 #51186
by D_an_W
Replied by D_an_W on topic I cannot update my devo 7e with Devention DfuSe
See section 2.2 of the user manual in the Wiki (
www.deviationtx.com/user-manual/user-manual-7e-10
), is your Devo 7E being detected in DFU mode at the top?
- kahuna001
29 Jun 2016 19:13 #51187
by kahuna001
Replied by kahuna001 on topic I cannot update my devo 7e with Devention DfuSe
I believed you have to right click on DFU program and run as administrator. Try that.
- choban
29 Jun 2016 21:09 - 29 Jun 2016 21:59 #51195
by choban
Replied by choban on topic I cannot update my devo 7e with Devention DfuSe
My Devo 7E is NOT being detected in DFU mode at the top. My USB cable is plug into my computer and to the Devo 7e. I have the "Program Update" screen showing on my Devo7e.
I just ran the DFU USB driver installer program 1.1, thinking I might have a driver problem
Then I reinstalled the Walkera Dfuse USB upgrade tools 2.31 program, but I still cannot see the devo 7e being detected in the DFU mode on the screen.
It's as thou my PC is not seeing the Devo 7e transmitter
I am using the USB cable that came with the Devo 7e package.
Any help is greatly appreciate.
Last edit: 29 Jun 2016 21:59 by choban.
- choban
29 Jun 2016 21:11 #51196
by choban
I am running the program as administrator. Any other suggestion would be greatly appreciated.
- D_an_W
29 Jun 2016 21:14 #51197
by D_an_W
Did you install the drivers as also mentioned in the Wiki?
- choban
29 Jun 2016 22:02 #51198
by choban
I just posted an update to what I tried, I must be missing something simple, there are alot of people on this forum who have made this update.
Could I be running the wrong software.
sure hope you can help
- choban
29 Jun 2016 22:12 #51199
by choban
I check to see if the driver shows up in device manager and it does NOT.
So I have Dfuse software loaded on my PC, I have the USB cable plugged into the computer and the devo7e, I press the ext on the devo7e and then turn it on and I still don't see the devo7e show up in the Dfuse software.
Is there something I'm missing.
- kahuna001
29 Jun 2016 22:33 #51200
by kahuna001
- 92zb
29 Jun 2016 22:55 #51201
by 92zb
Replied by 92zb on topic I cannot update my devo 7e with Devention DfuSe
Try a different usb cable !
- choban
29 Jun 2016 22:57 #51202
by choban
Kahuna001
it does not show up in device manager
- choban
29 Jun 2016 22:59 #51203
by choban
92zb
I am on my 3rd USB cable, still not working
- kahuna001
29 Jun 2016 23:45 #51204
by kahuna001
If it does not show up , you need to fix that first. Let me see your device manager screen shot. It has to show up somewhere in the device manager. Any yellow ! ?
- Arnold
29 Jun 2016 23:47 #51205
by Arnold
Replied by Arnold on topic I cannot update my devo 7e with Devention DfuSe
Did you read the section of the Deviation manual that talks about Windows device drivers? I believe that is your problem and it is a Windows issue, not an issue with your Devo controller.
- choban
29 Jun 2016 23:58 - 29 Jun 2016 23:58 #51206
by choban
This problem is fixed, I have 3 USB cables that are bad. Not sure how 3 USB cables go bad, but they do. The 4th cable worked and I now have deviation software on my controller.
Thanks for everyone's contributions, I really really do appreciate it.
Last edit: 29 Jun 2016 23:58 by choban.
- D_an_W
30 Jun 2016 04:45 #51211
by D_an_W
Glad you got it working, welcome to Deviation
Time to create page: 0.383 seconds
- I cannot update my devo 7e with Devention DfuSe
