I cannot update my devo 7e with Devention DfuSe
29 Jun 2016 17:21 #51178 by choban
I am trying to update my Devo 7e to run Devention firmware. I have installed the Defuse USB software, this looks like it worked. I plug my USB cable into my Devo 7e transmitter and into my computer. I press the EXT botton on the transmitter and turn it on, it goes into Program Update mode. I then go to select the upgrade botton in the Defuse USB software and the upgrade botton is grayed out, you cannot select it. I have reinstalled the software and rebooted my PC and still no connection. My PC is running windows 10, and I am using the latest version of Defuse software 2.?? and Devention 5.0 firmware. According to all the post this should be a no brainer. Would really appreciate some help.
29 Jun 2016 18:58 #51186 by D_an_W
See section 2.2 of the user manual in the Wiki ( www.deviationtx.com/user-manual/user-manual-7e-10 ), is your Devo 7E being detected in DFU mode at the top?
29 Jun 2016 19:13 #51187 by kahuna001
Replied by kahuna001 on topic I cannot update my devo 7e with Devention DfuSe
I believed you have to right click on DFU program and run as administrator. Try that.
29 Jun 2016 21:09 - 29 Jun 2016 21:59 #51195 by choban
My Devo 7E is NOT being detected in DFU mode at the top. My USB cable is plug into my computer and to the Devo 7e. I have the "Program Update" screen showing on my Devo7e.
I just ran the DFU USB driver installer program 1.1, thinking I might have a driver problem
Then I reinstalled the Walkera Dfuse USB upgrade tools 2.31 program, but I still cannot see the devo 7e being detected in the DFU mode on the screen.
It's as thou my PC is not seeing the Devo 7e transmitter
I am using the USB cable that came with the Devo 7e package.
Any help is greatly appreciate.
Last edit: 29 Jun 2016 21:59 by choban.
29 Jun 2016 21:11 #51196 by choban
I am running the program as administrator. Any other suggestion would be greatly appreciated.
29 Jun 2016 21:14 #51197 by D_an_W
Did you install the drivers as also mentioned in the Wiki?
29 Jun 2016 22:02 #51198 by choban
I just posted an update to what I tried, I must be missing something simple, there are alot of people on this forum who have made this update.
Could I be running the wrong software.
sure hope you can help
29 Jun 2016 22:12 #51199 by choban
I check to see if the driver shows up in device manager and it does NOT.
So I have Dfuse software loaded on my PC, I have the USB cable plugged into the computer and the devo7e, I press the ext on the devo7e and then turn it on and I still don't see the devo7e show up in the Dfuse software.
Is there something I'm missing.
29 Jun 2016 22:33 #51200 by kahuna001
Take a look at your device manager. Does STM shows up in the USB ?
29 Jun 2016 22:55 #51201 by 92zb
Try a different usb cable !
29 Jun 2016 22:57 #51202 by choban
Kahuna001
it does not show up in device manager
29 Jun 2016 22:59 #51203 by choban
92zb
I am on my 3rd USB cable, still not working
29 Jun 2016 23:45 #51204 by kahuna001
If it does not show up , you need to fix that first. Let me see your device manager screen shot. It has to show up somewhere in the device manager. Any yellow ! ?
29 Jun 2016 23:47 #51205 by Arnold
Did you read the section of the Deviation manual that talks about Windows device drivers? I believe that is your problem and it is a Windows issue, not an issue with your Devo controller.
29 Jun 2016 23:58 - 29 Jun 2016 23:58 #51206 by choban
This problem is fixed, I have 3 USB cables that are bad. Not sure how 3 USB cables go bad, but they do. The 4th cable worked and I now have deviation software on my controller.
Thanks for everyone's contributions, I really really do appreciate it. :) :)
Last edit: 29 Jun 2016 23:58 by choban.
30 Jun 2016 04:45 #51211 by D_an_W
Glad you got it working, welcome to Deviation :)
Time to create page: 0.291 seconds
