Devo 7e - Missing modules (Deviation 5.0 silp)
14 Aug 2016 19:46 #52755 by bianchifan
I postet a couple of days ago in another thread , so just 2nd try..
1. MCU swapped
2. TX module swapped, at the moment an A7105 is installed as told by FAQ
Deviation 5.0 nightly @ version silpstream doesn't recon my A7105 and cries for CYRF.. instead
What can I do?
15 Aug 2016 05:41 - 15 Aug 2016 05:42 #52761 by D_an_W
Did you edit the Hardware.ini to enable the module and remove the other?
This is mine (Also has extra switches)...
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
extra-switches=3x2
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105    = A13
has_pa-a7105    = 1
; enable-cc2500   = A14
; has_pa-cc2500   = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A13
Last edit: 15 Aug 2016 05:42 by D_an_W.
16 Aug 2016 09:52 #52802 by HappyHarry
Replied by HappyHarry on topic Devo 7e - Missing modules (Deviation 5.0 silp)
is tge cyrf module damaged? or have you shorted the wires going to it for the a7105?
16 Aug 2016 11:02 #52807 by bianchifan
Replied by bianchifan on topic Devo 7e - Missing modules (Deviation 5.0 silp)
HappyHarry wrote: is tge cyrf module damaged?
Don't know... but there is no Cyrix module, after extraction I threw it away.. :P
For I had the idea that the "Walkera module" may be assumed I checked the sources yesterday evening but I found only one point where this seems to be with no further action ...
So I decided to check some other builds:
As pointed in the theme the fault appears with the silpstream version, esp. deviation-devo7e-256-v5.0.0-65ec105-silpstream
Same situation with "normal" HappyHarry test version deviation-devo7e-256-v5.0.0-dd199b1
The message appears quite after switch on and there is nothing one can do...
Next tested version was quite normal deviation-devo7e-v5.0.0, the device started, pointed some stuff due to missing channels and pushed a message due to missing DSM2 protocol or similar, it could be quitted by pressing "enter", afterwards I saw the DEVO screen first time.. ;)
Hmm.. only one protocol at the moment, hubsan4.
At least I found a new nitely and loaded it..oh yeah, this seems to ride the trick!
Some stuff about channel 1 trouble - only the power switch is connected - followed by a deviation pic and a "Super CP" screen
My choose was silpstream because I wsitched the MCU to a 256k version and like to install additional pots and switches.
IIRC silpstream is needed unless I don't wanna build up my own production area.
16 Aug 2016 11:43 #52810 by HappyHarry
yes you need to use silpstream's or my builds for the full 256k abilities, it's clear why the error appears as you have removed the module, but i don't understand why you just can't press enter to bypass it with silp's or my builds but you can with the stock 7e build :/
30 Aug 2016 11:00 #53265 by bianchifan
HappyHarry wrote: it's clear why the error appears as you have removed the module, but i don't understand why you just can't press enter to bypass it with silp's or my builds but you can with the stock 7e build :/
Last weekend i tried a couple of different FW's.. the only FW allowing an error-bypass is the actual nitely, both tacts will run, ENT ot EXT.
No chance for the 265s, all will stuck :((
Time to create page: 0.146 seconds
