can't save models any more...
07 Sep 2016 12:10 #53572 by Podflyer
can't save models any more... was created by Podflyer
have a devo 10 running deviation 5.0 saved 3 models but now can't seem to save any more. can some one talk me through the process please.
07 Sep 2016 13:19 #53574 by Cereal_Killer
Replied by Cereal_Killer on topic can't save models any more...
Your batteries arn't to low are they?
Setup model
SWITCH MODEL FILES
Power off tx.
Check if it saved the new one
14 Sep 2016 05:21 #53852 by steadfast4life
Replied by steadfast4life on topic can't save models any more...
I also had this problem. The problem was I was using a 2s life battery which was far too low in voltage so the tx would power on but I couldn't save anything.
16 Sep 2016 07:05 #53904 by RRacer
Replied by RRacer on topic can't save models any more...
This is what I wrote in another thread about not being able to save when using a 2S lipo:
You need to edit tx.ini, and set batt_critical to a lower value.
I think the default is about 10500 (mV).
Set it to the lower limits of a 2-cell pack, say 7500 (7.5 V), and you should be fine.
batt_critical can not be edited in the tx gui, you have to do it from a computer over USB.
Do not edit with Notepad, use Notepad++ or some other proper editor.
Time to create page: 0.613 seconds
