Esky 150X, which protocol ?
04 Mar 2017 11:37 #59833 by dado099
Replied by dado099 on topic Esky 150X, which protocol ?
Hi wah,
just a confirmation: did you put throttle to right for more than 3 seconds, before spinning up, to unlock thr. channel ?
Please see this video for correct procedure:
04 Mar 2017 14:12 #59837 by wah_4515
Replied by wah_4515 on topic Esky 150X, which protocol ?
Oh~!!!! I am such an idiot !! It works fine !! thanks so much~!!!
04 Mar 2017 14:30 #59838 by SeByDocKy
Replied by SeByDocKy on topic Esky 150X, which protocol ?
wah_4515 wrote: Oh~!!!! I am such an idiot !! It works fine !! thanks so much~!!!
If you can post a 7E config file, I am interested.... Can't arm too (even if I press left or right)
04 Mar 2017 16:07 #59840 by wah_4515
Sure~~ There you go~~
basically it just a simple 4 channel setting.
note* I am not sure which channel is the flight mode, so I just set the Fmode knob to control all 5 6 7 channel, it does work for me.
04 Mar 2017 16:16 #59841 by SeByDocKy
wah_4515 wrote: Sure~~ There you go~~
Finally, I managed to arm .... from a fresh a config file. So the F150X is also working fine with the Esky150x protocol :)
03 Jun 2017 00:37 #62799 by wah_4515
Did some one set 150xp as (3g) mode?
14 Feb 2018 07:45 - 22 Feb 2018 10:14 #67511 by JazzMac
Replied by JazzMac on topic Esky 150X, which protocol ?
If still can't arm, check the flight mode switch. Must be hover but not maneuvering.
Edit: both modes alow arming.
Last edit: 22 Feb 2018 10:14 by JazzMac.
02 Jun 2020 08:08 #76414 by mangmeephol
Replied by mangmeephol on topic Esky 150X, which protocol ?
Hi
Are you have esky 150x model configuration file?
Time to create page: 0.190 seconds
