Esky 150X, which protocol ?
- dado099
02 Jan 2017 16:04 - 02 Jan 2017 16:05 #57476
by dado099
Replied by dado099 on topic Esky 150X, which protocol ?
Hi Moeder,
just for clarification, did you remove the old ESKY150 protocol, now obsolete ?
Thank you
Dado
Thank you
Dado
Last edit: 02 Jan 2017 16:05 by dado099.
- Moeder
02 Jan 2017 18:57 #57483
by Moeder
Replied by Moeder on topic Esky 150X, which protocol ?
I decided on replacing the old ESky150 with the new protocol, keeping the name as vlady suggested. I didn't want to make a hassle about changing the name, I think getting a quick merge to the nightlies is more important.
- Moeder
04 Jan 2017 20:54 #57536
by Moeder
The protocol has just been merged with the master branch (thanks, victzh).It should be in the forthcoming nightlies.
- dado099
07 Jan 2017 07:48 #57611
by dado099
Great Moeder !
I see it is updated on 5.0.0 main branch, but I prefer to use nightly builds,
do you think it is included from ver. 2017/01/05 ?
Thanks again for the effort.
- Moeder
07 Jan 2017 09:28 #57613
by Moeder
It has been merged to the github Master branch, which means it is included in the current nightlies. The 5.0.0 release is fixed and won't get changed, except for the builds vlad makes in a separate thread in this forum, which is basically the 5.0.0 release including all new protocols.
- dado099
07 Jan 2017 11:12 #57617
by dado099
Ok, that's fine
- Käseknigger
14 Jan 2017 09:26 #57928
by Käseknigger
Replied by Käseknigger on topic Esky 150X, which protocol ?
@all: Again thanks a lot
@ Moeder: Do you know, when the new documentation will be merged into the main trunk? As currently the doc is still for the old version.
- Moeder
16 Jan 2017 20:45 #58054
by Moeder
For probably many reasons only a few people have write access to the DeviationTX repositories, with current main developers being only hexfet, goebish, victzh and vlad_vy. The father of deviation PB is currently on a break and mwm also unavailable. It's up to one of those few to do the merge. I suppose it wouldn't hurt to open up access to the manual repository slightly more, since changes in there don't threaten the high stability of the nightly builds, which probably many of us are using.
16 Jan 2017 20:57 #58055
Replied by FDR on topic Esky 150X, which protocol ?
I merged your documentation change...
- Moeder
16 Jan 2017 21:09 #58056
by Moeder
Fantastic, sorry I forgot you in the list!
17 Jan 2017 04:59 #58072
Nevermind, I don't develope it, just playing the admin game...
- wah_4515
03 Mar 2017 11:57 #59799
by wah_4515
Replied by wah_4515 on topic Esky 150X, which protocol ?
Excuse me ~~
I am new on divationtx user, I just got a devo7e and esky150x, I've installed the 3 in 1 protocol.
I've compared devo10 and devo7e firmware, I found that there is an extra folder called "protocol", I just wonder can I change something in your attachment and use to devo7e ? thanks
- Moeder
03 Mar 2017 15:09 #59803
by Moeder
The esky150x protocol is part of the current nightlies builds which you can download via the link on the menu on the left side.
On devo7e and f7 the modules are in separate folder due to memory restrictions, all other devos have them included in the rom. The protocols featured are the same for all devos.
- dado099
03 Mar 2017 15:16 #59804
by dado099
If you have a 7e, you don't mind about other tx'es,
simply download last nightly for 7e, install following the instructions present in the forum, and you are ready to go.
For 150x config, you can search if it already exist on the forum, otherwise just ask if anyone can share it with you.
Personally I don't have the 150x but I'm sure someone in this thread has it.
- wah_4515
03 Mar 2017 15:25 - 03 Mar 2017 15:30 #59805
by wah_4515
em~~ I've a 150 before. it's work fine, it broken by some... accident:sick: and I got 150x instead.
I've used the latest nightly build (3/3/2017) and it successfully bound (ali, ele are ok), but the throttle has no respond for 150x
Last edit: 03 Mar 2017 15:30 by wah_4515.
- dado099
03 Mar 2017 15:37 #59807
by dado099
mmmhhh, I remember something about the throttle not working, but I remember it was fixed.
Just try to set 7ch on the protocol, and make -100 fixed not used channels.
- wah_4515
03 Mar 2017 15:58 - 03 Mar 2017 16:31 #59809
by wah_4515
Yes I saw that on this topic I've tried to enable channel 5 6 7 and set them all to 0, three of them, and then set it all to -100, and then -125.. three of them, but no luck
maybe I attach my setting for reference, let see anything wrong?
Last edit: 03 Mar 2017 16:31 by wah_4515.
- dado099
03 Mar 2017 16:35 #59810
by dado099
Ok, I will check your .ini but please I need some time....
- wah_4515
03 Mar 2017 16:39 #59811
by wah_4515
Thanks so much~~~~
- SeByDocKy
04 Mar 2017 08:03 #59831
by SeByDocKy
Replied by SeByDocKy on topic Esky 150X, which protocol ?
I will receive the F150x, so I am interested too
Time to create page: 0.335 seconds
- Esky 150X, which protocol ?
