Low range issue only about 15 feet from my 3 in 1 module installed in a devo 7e.
22 Oct 2016 11:56 #55270 by FJL
Hi All,
I have a low range issue with my 3 in 1 module purchased from BG around april of this year and recently installed. I am getting 3.28 volts on the modules vcc pin. Is that voltage ok or does it need to be 3.3v or a little higher? What else should I check? My Taranis works fine with the receiver so I know its not that.
Thank you in advance for any suggestions.
Fab
22 Oct 2016 23:13 #55291 by HappyHarry
the voltage is ok at that level bud, what protocol are you using, and what power level? (I presume it's frsky as you say taranis but the taranis can use other modules including the 4in1). do other recievers on the same protocol have better range? do protocols that use a different rf chip have good range?
23 Oct 2016 11:57 #55304 by FJL
Hi HappyHarry,
Yes, I'm trying to use frisky protocol and tried different power settings but not sure which I should be using. I'll try to connect to a couple other models and check the range. thank you.
23 Oct 2016 12:21 #55305 by FJL
I'm getting the same low range using the hubsan protocol also. I forgot to mention I added an antenna mod 5dbi to see if that would help but no go.
26 Oct 2016 22:30 - 26 Oct 2016 22:31 #55429 by FJL
I decided to change out the 3 in 1 and installed a CC2500 module and the range is fine with this module. Really only interested in using Frsky and DSMX. Though the 3 in 1 would have been nice.
Last edit: 26 Oct 2016 22:31 by FJL.
Time to create page: 0.701 seconds
