shown value for throttle is 100 instead of -100
14 Dec 2016 10:47 #56810 by thommythekid
I am new to deviation and I have oberved a behavoir that confuses me:
After implementing an example model.ini from the model list I have recognized,
that when the throttle stick is in the idle position (lowest position) the value showed
on the display was +100 !! So I had a little fear, that the motors of my quad would
immediately go to 100% throttle after arming.
Well, that was not the case, the throttle worked as it should. After arming, the motors
stayed off and by giving a little throttle they started to spin.
I do not understand why the throttle stick shows +100 then idle and -100 when full
throttle is given. I also tried to reverse the stick, but independent from the setting
(normal or reverse) the shown number of +100 is the same when the throttle
is idle.
Can anybody explain ?
thanks & kind regards
ThommyTheKid
14 Dec 2016 11:54 - 14 Dec 2016 11:57 #56812 by Thomas.Heiss
Replied by Thomas.Heiss on topic shown value for throttle is 100 instead of -100
Throttle cut switch active? Wrong mixer values?
What are your throttle CHANNEL values in the monitor on a new model with the template defaults (reset)?
It shall be -100 if the stick is off is down or the TC / hold switch activated. N/R on THR channel itself?
Maybe you can configure -100/+100 for the throttle stick itself, e.g heli pitch down instead of up for some very rare pilots???
However I did not test this.
But down is -100 for me, for sure.
Last edit: 14 Dec 2016 11:57 by Thomas.Heiss.
14 Dec 2016 12:02 #56813 by FDR
You need to ask the author of that model.ini file.
We can't really help without seeing the model.ini anyway...
14 Dec 2016 13:44 #56817 by thommythekid
Replied by thommythekid on topic shown value for throttle is 100 instead of -100
thanks for the answers so far. I will check with the default settings.
I think I remember that before applying any model.ini file, I saw that -100
when the stick position was on the lower end.
But as I wrote, I also got confused because of the stick simply seems
to be reversed (in terms of the output number shown in the display)
and if I go into the setting and reverse it, I don't see a change. And in
addition the actual behavoir is correct again (stick low position motor
off - stick high position - max. throttle).
But OK, so far thanks for the information that you would also expect -100 as
the value shown when the strottle stick is at the lower end.
So, I will check with the default (model20 should be still default) and in
addition, I will check and post the model.ini file here.
thanks
ThommyTheKid
Time to create page: 0.072 seconds
