Need help. Motors on wizard spin all the way up...
30 Mar 2017 15:31 #60944 by Mikewoodkozar
So I don't know what's happening but when I see if the radio is working with the props off the motors spin all the way up to full speed when I have the stick at a low throttle. I can just leave the throttle stick in the low position; just enough to start motors spinning barely. Then I leave the stick in the same position; touch nothing else and they start quickly revving all the way up.
I'm using a Devo 10 with deviation 5.0
Orangerx 615x receiver
Eachine wizard x220
Seriously driving me crazy can anyone help please!
Thank you
30 Mar 2017 17:42 #60948 by Deal57
Are you running Betaflight? Did you make any changes to the stock setting or maybe flash a new version? I don't have the x220, and the brushed settings are probably different, so check out www.propwashed.com or RCGroups.com for info on this model. On my F3 Evo brushed controllers I need to turn on motor_stop in the Configuration page. I also have to use the pwm command in the CLI "set motor_pwm_rate = 32000.
30 Mar 2017 19:31 #60949 by TheSFReader
Replied by TheSFReader on topic Need help. Motors on wizard spin all the way up...
Mike, As far as I understand, (from some youtube video by Joshua Bardwell, no link, he posts too much to find it again), the spin-up is quite normal : the flight controler tries and accelerate a motor to compensate "some" micro deviation from the attitude he thinks you want. And since there is no propeller, effect on attitude is --->nothing. So he tries and increase the props effect by increasing motor speed, and keeps increasing until he gets an effect...
I suppose you could check if that's the same phenomenon you're having by starting the copter from a slightly differently near horizontal attitude, and most probably it'll be a different motor that starts to spin up...
30 Mar 2017 20:11 #60950 by Mikewoodkozar
Replied by Mikewoodkozar on topic Need help. Motors on wizard spin all the way up...
That's totally correct and it was a oh dumb me moment. So thank you very much. I just didn't want to potentially fly it and have it take off.
Then like five min later I went to put it back together and I cooked the rx in he process by stupidly having the wrong pins in the servo lead :(
Damn and just when I think I had it figured out.
Time to create page: 0.299 seconds
