Devo 10 + OrangeRX R110 (Spektrum DSMX): Arming?
- cjochetz
11 Apr 2017 22:35 #61383
by cjochetz
Devo 10 + OrangeRX R110 (Spektrum DSMX): Arming? was created by cjochetz
Hey, all. After much gnashing of teeth, I finally got my Devo 10 and OrangeRX R110 bound using DSMX. Now, how the heck do I arm the motors? I've read something about Spektrum using AUX2 for arming. Now what?!?
Thanks in advance! Love the education I'm receiving from this place!
- Deal57
11 Apr 2017 23:39 #61384
by Deal57
Replied by Deal57 on topic Devo 10 + OrangeRX R110 (Spektrum DSMX): Arming?
Arming is a function of your flight controller on your model. What model/FC are you using?
- cjochetz
12 Apr 2017 00:17 - 12 Apr 2017 00:18 #61385
by cjochetz
Replied by cjochetz on topic Devo 10 + OrangeRX R110 (Spektrum DSMX): Arming?
It's a Diatone Crusader GT2 200 with a D-Link V4 board.
Last edit: 12 Apr 2017 00:18 by cjochetz.
- Deal57
12 Apr 2017 03:34 #61388
by Deal57
Ok, so this is a betaflight quad. That's good because there is a lot of info out there. I haven't used this model, but i use betaflight on my Lantian Hex frame with an F3 board and the OrangeRX 110. I configure betaflight to arm with AUX1, set to 1500 and above. Then I set up a switch on Deviation as a simple curve on channel 5.
Let us know how it goes!
- cjochetz
12 Apr 2017 05:06 - 12 Apr 2017 05:07 #61390
by cjochetz
I think my problem is that the throttle channel won't go low enough to arm. With the stick all the way down, the throttle on the Receiver page in Betaflight still reads 1159.
Last edit: 12 Apr 2017 05:07 by cjochetz.
- Deal57
12 Apr 2017 12:15 - 12 Apr 2017 12:16 #61397
by Deal57
Take a look at the rxrange CLI command in betaflight (ex. rxrange 0 1159 1841). This will allow your FC to see end points of 1000-2000 and let you use all the normal stick movements and switch configurations.
Last edit: 12 Apr 2017 12:16 by Deal57.
- cjochetz
12 Apr 2017 15:19 #61403
by cjochetz
Thanks, Deal57. I find the same thing through much googling last night. I'll give it a try this morning.
One thing I'm finding about this hobby: one needs to be equal parts pilot, electrician, engineer, and programmer :/ I got into it for the flying but I'm finding so much more.
Time to create page: 0.886 seconds
- Devo 10 + OrangeRX R110 (Spektrum DSMX): Arming?
