26 Oct 2017 19:04 #65285 by dready
Replied by dready on topic New TX from Banggood
Fernandez wrote: I hope that Jumper will make the next model more in a shape like Turnigy evolution, inc the the hall gimbals and an embedded antenna and indeed add the voice mod, it would be me ideal controller.
Deviation it is super, I never ahd any control related issues and still stongly believe a control of the RF over SPI is the best solution out there, beter than Taranis with module via pxx etc.
And I hope that the hall gimbals will be available for the current release
29 Oct 2017 13:38 #65344 by llinde
Replied by llinde on topic New TX from Banggood
Iroquois wrote: The original sticks are ajustable over a fair range, but there's no way of locking them other than a spot of glue
A simple lock nut (M3) will also do the trick, no glue needed.
29 Oct 2017 14:56 #65345 by Iroquois
Replied by Iroquois on topic New TX from Banggood
Why didn't I think of that?
30 Oct 2017 21:28 - 30 Oct 2017 21:54 #65369 by fneuf
Replied by fneuf on topic New TX from Banggood
Hello there,
After lurking this thread for some weeks, I jumped in and bought the jumper (pun intended). Finally I did received mine today and so far I have noticed:
  • the battery rack is installed (and I can confirm the Turnigy 1600 to be a nice fit)
  • the USB port is the accessible one
  • it beeps in addition to vibration,
  • the installed firmware is the specific T8SG build dated from the 05/10 (special thanks to vlad_vy on that)
Should I update it first thing?
ltwvince wrote:
dc59 wrote: Jumper replied, both T8SG & DEVO hall gimbals are at molding stage now, beta version will be released soon.
If they can give good price for beta testing, please let us know. I have this T8SG, Devo 7E and Devo 12E. Thanks.
IMHO :
  • Beta testing should not imply payment from the tester, but should be seen as a gracious opportunity for the brand to have dedicated and motivated ressources in their team.
  • And should a payment be done to guarantee the "motivation" from the maker POV, it should be clear that the testers will be upgraded and receive the final product in the end as an acknowledgement of their efforts.
Those are the only win-win scenario I could think of and see as acceptable.
Last edit: 30 Oct 2017 21:54 by fneuf.
31 Oct 2017 09:12 #65376 by dc59
Hi FDR,
Jumper got problem when they try to register Deviation account, I send you a PM for it.
31 Oct 2017 09:35 #65377 by dc59
Jumper tried to install a 2.4 inch OLED to Devo7E , but it doesn't work , can anyone help to build a correct firmware?
They follow this post :
www.deviationtx.com/forum/7-development/...-screen?limitstart=0
and try to modify LCD.C , but they failed.
File Attachment:
File Name: SSD1309-Re...n1.1.pdf
File Size:1,761 KB
File Attachment:
File Name: 286495E.zip
File Size:10 KB
File Attachment:
File Name: UG-2864ASY...0-31.pdf
File Size:357 KB
OLED data sheet is attached.
31 Oct 2017 17:30 #65384 by FDR
Replied by FDR on topic New TX from Banggood
dc59 wrote: Hi FDR,
I've activated them manually.
Please tell them to try to log in.
If they can't, I'll need to put them on the white list...
01 Nov 2017 00:25 #65388 by dc59
FDR wrote: I've activated them manually.
Thanks FDR, I will ask Jumper to login again.
01 Nov 2017 00:27 #65389 by dc59
Connection of Jumper's OLED pin out.
01 Nov 2017 00:29 #65390 by dc59
One more question , except Moeder , is there any other developer didn't get sample T8SG? if yes, please let me know , thank you.
01 Nov 2017 04:41 #65392 by norulers
Replied by norulers on topic New TX from Banggood
New schematic
01 Nov 2017 05:16 #65394 by dc59
Jumper's first batch of T8SG analog/digital hall sensor gimbals and Walkera DEVO hall sensor gimbals will be released at end of November , of course these upgrade kits will send to Deviation developers for further testing.
01 Nov 2017 05:49 #65395 by SeByDocKy
Replied by SeByDocKy on topic New TX from Banggood
dc59 wrote: Jumper's first batch of T8SG analog/digital hall sensor gimbals and Walkera DEVO hall sensor gimbals will be released at end of November , of course these upgrade kits will send to Deviation developers for further testing.
Great news :)
01 Nov 2017 08:41 #65397 by rsh78ph
Replied by rsh78ph on topic New TX from Banggood
Just got my Jumper T8SG, manual indicated to have my firmware updated which I did (10-27).
I was about to bind my drone when observed that both aux4 and aux5 didn't respond in the channel monitor.
Is it a firmware issue (wasn't able to test the old one) or is it a hardware issue? Or am I just missing something.
Any info would be helpful before I send it back.
Thank you
01 Nov 2017 09:04 #65398 by Twilight_Sun
Replied by Twilight_Sun on topic New TX from Banggood
try to calibrate all controls (including aux4/5)
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
01 Nov 2017 09:09 #65399 by goebish
Replied by goebish on topic New TX from Banggood
rsh78ph wrote: Just got my Jumper T8SG, manual indicated to have my firmware updated which I did (10-27).
Thank you
When creating a new model AUX4 & AUX5 pots aren't mapped to any channel, that's up to you to program that in the mixer page.
01 Nov 2017 09:43 #65401 by rsh78ph
When creating in the mixer page, the switches are detected when you are at the source but aux 4 and aux 5 aren't picked up.
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
01 Nov 2017 10:16 #65402 by goebish
Ah ? I've just checked on mine and it's working fine, they're picked up automatically.
I'm running a firmware I built ~2 weeks ago ( here ) but it shouldn't be different.
Try it anyway, if it doesn't work either, then open your transmitter and check the connections.
01 Nov 2017 10:29 #65403 by dc59
Hi Deviation developers , "norulers" is Jumper's contact window , his first post .
01 Nov 2017 10:29 #65404 by vlad_vy
First, try calibrate knobs along with sticks, and report result.
Time to create page: 0.134 seconds
