- škrat14
16 Mar 2018 15:57 #68134
by škrat14
Replied by škrat14 on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
How format transmitter USB drive
16 Mar 2018 16:24 #68135
Replied by vlad_vy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
As any removable drive. Connect transmitter to PC USB port.
- škrat14
16 Mar 2018 19:38 #68138
by škrat14
I uploaded a new Firmware and nothing happened is still locked in usb mode.
what would be wrong
what would be wrong
- Alvarez
16 Mar 2018 19:44 #68139
by Alvarez
Replied by Alvarez on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Check the enter button in case it could have been blocked
- škrat14
16 Mar 2018 20:09 #68141
by škrat14
The button is not blocked, even I replaced it but nothing happened still locked
17 Mar 2018 06:26 #68154
- škrat14
17 Mar 2018 15:38 #68160
by škrat14
In usb mode I can not connect but in the dfu mode it works in rc group and yutube that also have the same problem with locked usb mode
- Ariete
17 Mar 2018 17:25 #68162
by Ariete
Replied by Ariete on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
To enter USB mode you have to press ent while powering up.
- škrat14
17 Mar 2018 18:25 #68163
by škrat14
Is locked in usb mode even if you do not press the switch in this is big problem.Where you can not do anything else
- škrat14
17 Mar 2018 18:30 #68164
by škrat14
I apply video I hope it works
- aMax
17 Mar 2018 19:28 #68165
by aMax
Replied by aMax on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Seems to be a new feature...
Just a joke.
Attach the TX to your computer and test if you have access to the filesystem, if not , only formating the drive will help.
If this fails, you are at the same point where I have been two weeks ago with my 7e. Good luck.
Just a joke.
- aMax
17 Mar 2018 19:53 #68166
by aMax
Ok. this seems to be only a driver problem, as I mentioned before, I had this issue some weeks ago, but got no answer on the forum (ignored?)
Just from one power up to the next this had happend.
After a week of testing, I could install Walkera Devention an run it, but no chance to get Deviation back. No access to the drive for the file system. I played around with Zadig but no success. After all was messed up I tried to install the origin Windows driver again....
and now it worked for me. My Devo was back on the USB Windows track.
Got my drive back and formated. Deviation was back.
What caused this issue,....only the devs can tell.
škrat14 wrote: In usb mode I can not connect but in the dfu mode it works in rc group and yutube that also have the same problem with locked usb mode
- škrat14
17 Mar 2018 19:55 #68167
by škrat14
I dont access to the filesystem.How did you solve the problem whit 7e.
- aMax
17 Mar 2018 20:08 - 17 Mar 2018 20:33 #68168
by aMax
Read the post above.
My Windows told me, all drivers where ok but refused the drive access and formating the drive.
Once Windows was forced to reinstall the driver again , all issues were solved.
But why the Devo crashed the file system from one moment to another...I don´t know. My Devo file system had worked for FOUR years
with out any issue, I always do a save remove from the port.
Edit: Since the DFU mode is ok, your goal should be to get the USB mode on the computer working again. There is no other option.
Edit1: If nothing helps your last option is someone how knows Linux and can work with Busybox and/or file systemtools to
get the flags right for the MSdos filesystem. That´s what I did additionally.
A simple tool for Deviation that could be flashed via DFU mode and only checks the space & flags and sets those flags would be nice, but I don´t know any. .
Last edit: 17 Mar 2018 20:33 by aMax.
- WimH
21 Mar 2018 16:19 - 21 Mar 2018 16:20 #68246
by WimH
I was just about to try this ( the problem came back after a while) when i saw there were other users with this same problem
( CYRF not detected). I installed the latest version (19/03) and that seems to have fixed things properly, thanks a lot!
I noticed all messages went to my spam folder, fixed that too I hope. I like this TX a lot and am determined to fix all eventual problems and get to grips with the software too. Thanks for adding the (trim) flight modes as well. Can you tell me how the "virt" switches work in this context?. Are they logical switches that can be programmed somewhere?
Thanks again,
Wim
Replied by WimH on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
vlad_vy wrote: Probably something is wrong with filesystem. Try to format USB drive, write filesystem and use "Safely Remove Hardware".
Thanks again,
Wim
Last edit: 21 Mar 2018 16:20 by WimH. Reason: clarification
21 Mar 2018 16:28 #68247
It is 10 virtual channels (scroll channels down to virtual channels), they usually used as mediator for complex mixers. You can use it for setup multi-pos switch.
- WimH
21 Mar 2018 21:30 #68251
by WimH
Ah, I get it now. I'll try figuring it out.
- sfjuocekr
05 May 2018 02:57 - 05 May 2018 06:32 #69053
by sfjuocekr
Replied by sfjuocekr on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Has anyone tried swapping out the RF module?
It looks like this uses the same-ish, but shielded, RF module? Edit: salvaging the IR4X should work too.
If that fixes the RF issues, it would make a relatively cheap replacement!
Maybe if I can afford it next month I'll swap it, test it and report back!
Edit: anyone tried to update the firmware on the 4IN1 module?
Last edit: 05 May 2018 06:32 by sfjuocekr.
- Alvarez
05 May 2018 07:43 #69056
by Alvarez
Its exactly the same and i see many people in rcgroups that have changed it
05 May 2018 09:03 #69057
IR8M 4in1 module has not firmware, it managed by transmitter firmware.
Time to create page: 0.271 seconds
- iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
