Flysky Vario Support
- propnut
28 Aug 2018 10:15 - 28 Aug 2018 10:16 #70503
by propnut
Flysky Vario Support was created by propnut
Hello all
I would like to use the Flysky/Turnigy Variometer to display and alert on my Altitude. There is an Alt option under the Telemetry settings but the Variometer does not seem to be detected and I get no values. When I bind the same receiver/sensor pairing to my Flysky i10 radio it works perfectly.
Is the module actually supported or is the Alt setting just a place holder for further development.
I have installed the latest nightly build.
Last edit: 28 Aug 2018 10:16 by propnut.
- propnut
12 Sep 2018 19:52 #70854
by propnut
Replied by propnut on topic Flysky Vario Support
Hi Guys
Sorry to ask again but I would really like to be able to utilise my Altitude sensor. Is there any chance of getting the Turnigy/Flysky CAT-01 sensor supported.
Link to Sensor
Or can someone tell me what the ALT telemetry field is for under the AFHDS-2A telemetry settings if not for an Altitude reading ?
Link to Sensor
13 Sep 2018 17:08 #70889
Replied by hexfet on topic Flysky Vario Support
Altitude is not currently supported in the protocol. Looks like it needs support for a different telemetry packet type (AC frame). Can add it to the to-do list...
- propnut
17 Sep 2018 12:32 #70946
by propnut
Thanks hexfet, that would be awesome. Really appreciate all the hard work you developers put in to give us all this great RC system. You and the guys over at OpenTX have really changed this hobby.
02 Dec 2018 01:54 #71948
Test build
(dc342d8) is available
. Adds support for telemetry data Vario, Altitude, Current, RPM, GPS Lat, GPS Long, and GPS Altitude.
Not sure this will work because couldn't find any hard data on the 4-byte telemetry value packet format. I assumed it's just an extension of the packet format that was already in place. Used the telemetry sensor definitions from here to add the new values.
There are two sensor definitions for a vario sensor: "CLIMB_RATE" and "VERTICAL_SPEED". May need some trial and error testing to get the code working.
- ballbear
25 Nov 2024 21:55 #78519
by ballbear
Replied by ballbear on topic Flysky Vario Support
Hello Hexfet,
is this here noticed Test Build ... 5284cc1 from 12.7.2019 included in Your Nightly Builds 408f8c0 from 23.1.2023?
With this I am using FlySky FS-CVT01 voltage sensor, but I have troubles with Altitude sensor FS-CAT01.
It is only blinking with red LED ... So I am looking for the solution and I found Your message about "telem_flysky" Test Build , but it is older then the Nightly Build ....
Which version is the right one?
Many many thanks in advance for your answer.
Pavel
Pavel
30 Nov 2024 00:49 #78520
Please try the telem_flysky build and see if it helps with the altitude. Test on the bench first as there were quite a few changes. That code was never merged to the main build because it was untested. If it works I'll merge and make a new build.
What transmitter do you have? Due to memory constraints the altitude telemetry is only available on txs that support extended telemetry.
- ballbear
30 Nov 2024 07:08 #78521
by ballbear
Hello many thanks for your replay.
I have Jumper T8SG V2 Plus ( Carbon version with normal LCD )
The Voltage works and RSSI also ...
If it can work on my Transmitter, I will test it and I will inform You about the result.
I hope I can do it till the mid of next week.
If there is no chance with my Tx, write it please now.
Have a nice day
Pavel
Have a nice day
Pavel
30 Nov 2024 13:57 #78523
It's good, the T8SG supports extended telemetry. Good luck and thanks for testing.
- ballbear
30 Nov 2024 22:11 #78524
by ballbear
I did these steps:
1) From the Tx i copied all files to the notebook.
2) I unzip the downloaded file from your Test build.
3) I errased all files from Tx
4) I copied the test files to the transmitter.
5) I copied to Tx my model file, which is using the Flysky receiver with telemetry.
5) I asked Windows to remove the drive and after confirmation I close the USB drive on the Tx and disconnect it from notebook.
When I started the Tx and bind it with Rx, I didn´t see any change in telemetry ...
To be sure, I am using AFHDS 2A protocol.
What is curious, looking About Deviation shows version -408f8c0 .... Is it OK?
Maybe I am making something wrong ....
Any advice is welcome
Pavel
I did these steps:
Pavel
02 Dec 2024 02:27 - 02 Dec 2024 02:28 #78525
The 408f8c0 version is the current latest, not the telem_flysky version. After the telem_flysky version is installed the display should show 5284cc1.
Copying the files is the second step of the installation process. First step is installing the firmware (the .dfu file). See the installation steps at this link .; You don't need to copy the files again, just install the .dfu firmware.
Last edit: 02 Dec 2024 02:28 by hexfet.
- ballbear
02 Dec 2024 15:13 #78526
by ballbear
Hello and thanks for the help.
I did the upgrade twoo years ago last time and I didn´t remember the right way...
So now the Test build is installed and some simple tests are done.
In Telemetry monitor on position 2 there is the temperature shown, it works fast.
On position 6 there is shown the altitude, but this is not working well now.
I live 230 m above the sea level.
When the sensor was positioned outside, the temperature fall down to 4 degrees of Celsius and on position 6 was shown value - 5600m approx. ( Minus 5600m)
Moving the sensor inside the house, temperature changed to 19 degrees and altitude to Minus 8000 approx ( in reality the altitude was the same ), moving the sensor upstairs one level, the temperature changes to 23 degrees and altitude to Minus 8135 meters.
What I am missing is the possibility to set up the altitude to zero, to measure the height of the plane above the ground.
So this is first report
Have a nice day
Pavel
Have a nice day
Pavel
- ballbear
02 Dec 2024 15:53 #78527
by ballbear
in 30 minutes without moving the sensor the value changed to minus 7953m, temperature is the same.
- ballbear
02 Dec 2024 16:19 #78528
by ballbear
Do You have seen this?
forums.parallax.com/discussion/173396/ge...ed-with-flysky-i-bus
Could it be helpfull?
Greetings
Pavel
Greetings
Pavel
- ballbear
02 Dec 2024 16:24 #78529
by ballbear
After last 30 minutes the temperature raised to 24 degrees and the altitude value is changed to minus 7972m.
- ballbear
02 Dec 2024 17:42 #78530
by ballbear
Now we have 23 degrees and minus 7887 m .
Physical position still the same ...
02 Dec 2024 19:08 - 02 Dec 2024 19:10 #78531
It's encouraging anything is displayed
Is the temperature accurate? The numbers sound reasonable.
The information at the link is about the interface from the sensor to the rx, which is different from the over-the-air information.
I did spot a bug that would occur if more than one sensor was sent in a packet so that might be what's happening. Updated test build is available ( 908fa3a ).
Last edit: 02 Dec 2024 19:10 by hexfet.
- ballbear
02 Dec 2024 19:24 #78532
by ballbear
Hello, thanks for fast response .
The displayed data came from receiver ( RSSI and battery voltage ) and from altitude sensor ( temperature and altitude )
I am going to connect also the Voltage sensor, which I have, and we will see the influence.
Should I upgrade to the new Test build now and after the upgrade make the test with the connected second sensor, or it would be interesting for you to make the test with the old one Testbuild?
- ballbear
02 Dec 2024 19:31 #78533
by ballbear
I am not sure if the version Plus would work, while those Carbon Plus version have normal display ....
I will try it, but the last trial I did with non Plus version.
- ballbear
02 Dec 2024 21:08 #78534
by ballbear
Unfortunatelly I was right, there is problem with display.
Could You prepare and upload also version for V2, but not Plus, please ?
Many thanks for your effort in advance
Pavel
Pavel
Time to create page: 0.097 seconds
- Flysky Vario Support
