Differential thrust
- 1942keremeos
17 Nov 2018 16:14 #71775
by 1942keremeos
Differential thrust was created by 1942keremeos
I'm trying to mix differential thrust in the Jumper t8sg plus but not having much luck. Has any body done this?
- spacecase
29 Jan 2019 05:25 #72606
by spacecase
Replied by spacecase on topic Differential thrust
I have two 10 amp escs and B1806 motors Iv been thinking of using in a wing with differential thrust.
You would have to go into mixers and use rudder for source (unless you were using ailerons). Hum then two channels for port and starboard throttle.
Ill have to get back, but its a really good question.
- 1942keremeos
29 Jan 2019 20:09 #72616
by 1942keremeos
Replied by 1942keremeos on topic Differential thrust
I have a few planes with diff thrust but I use a spectrum dx6 with them,simple only 2 mixes. One esc in throttle second in aux channel. Even to get duel rates with deviation is a long process. Kind of gave up let me know if you come up with a way. Thank you.
29 Jan 2019 20:43 #72617
Replied by hexfet on topic Differential thrust
See
this thread
. Need one channel for each motor. One way to do it is complex mix with two pages, first page has THR as source, second page is Add mix with rudder source scaled appropriately. Second channel is the same but with rudder inverted.
- jejeg
- spacecase
02 Feb 2019 04:39 - 02 Feb 2019 04:41 #72667
by spacecase
Cool hey so now is when we can take the file from jejeg model26.ini and dump it into ones transmitter usb drive fold "models".
Then load new model on transmitter and pull that model up, it will be there?
This is fantastic we can see how you did it thanks, how cool that saves so much time.
Last edit: 02 Feb 2019 04:41 by spacecase.
- jejeg
02 Feb 2019 18:31 - 02 Feb 2019 18:32 #72672
by jejeg
Replied by jejeg on topic Differential thrust
Motor 1 : channel 3 (with devo receiver)
Motor 2 : channel 7
Do not connect on channel 4
Fmod0 : no mixing
Fmod1 : mixing on
Good flight
Jérôme
Motor 2 : channel 7
Fmod0 : no mixing
Fmod1 : mixing on
Good flight
Jérôme
Last edit: 02 Feb 2019 18:32 by jejeg.
Time to create page: 0.031 seconds
- Differential thrust
