JUMPER T8SG V2 PLUS and deviation uploader
25 Nov 2018 19:28 #71882 by ALF26540
Hello
I have just acquired a JUMPER T8SG V2 +. I have to download deviation UPLOADER. when I starts it and when I connect the radio ( activated USB port) the transmitter is not recognized. Which is the approach to be made so that it is recognized
Thank you for the answers
26 Nov 2018 05:54 #71894 by vlad_vy
Replied by vlad_vy on topic JUMPER T8SG V2 PLUS and deviation uploader
First you need install USB driver with DFU USBDrv Installer-1.1 and use Deviation Uploader-0.9.0. To get firmware update mode you need press EXT and short press Power On.
www.deviationtx.com/downloads-new/category/161-dfu-usb-tool
28 Nov 2018 10:22 #71918 by ALF26540
Replied by ALF26540 on topic JUMPER T8SG V2 PLUS and deviation uploader
hello
after doing the manipulation you gave me, Deviation Uploader marks me unknown
is the radio compatible with Deviation Uploader?
28 Nov 2018 10:50 #71919 by vlad_vy
Yes. You need install Deviation USB Driver with DFU USBDrv Installer-1.1, not Walkera driver.
29 Nov 2018 07:22 #71934 by ALF26540
Yes, i install USB driver with DFU USBDrv Installer-1.1 and use Deviation Uploader-0.9.0.. Deviation uploader marks me unknown or DEVO 7 but not accede to the transmitter. I tried with different cable but nothing helps
the version of my transmitter dates from January 2018 and I want to update it with the November 2018 version
i am blocked
thanks for your help
29 Nov 2018 08:53 #71935 by vlad_vy
If T8SG V2 Plus transmitter detected as DEVO 7E it's normal and you can update firmware.
25 Dec 2018 17:21 #72113 by ALF26540
hello
I still have no connection between the emeter and deviation uploader. it seems to me that normally deviation should read the version of the firm that is in the emeter but there is nothing happening
can you tell me why?
Time to create page: 0.101 seconds
