Devo 12S nightly
13 Feb 2013 08:24 #6342 by SamtheMan
Devo 12S nightly was created by SamtheMan
Is this far enough along where I can buy a Devo 12s now? (I told my wife I wouldn't buy a Devo 12s until this firmware was mostly functional).
Sam
13 Feb 2013 11:09 #6349 by Hexperience
Replied by Hexperience on topic Devo 12S nightly
Working well for me. :)
17 Feb 2013 14:55 - 17 Feb 2013 15:16 #6480 by Hexperience
5f1e3695ea6e gave me a couple of problems.
When pressing the button to go into TX config, momentarily a battery warning page would flash on screen and disappear. My battery is above the alarm setting.
Also, it seems like it stopped being able to write to the tx.ini file. When I select a different model, then turn off the devo, then back on, it would go back to the model I previously had selected.
I went back to an older version for the moment, and will try flashing it again to make sure these issues are repeatable.
Re-flashed re-installed FS the battery alarm is not allowing the tx.ini file to be written.
Last edit: 17 Feb 2013 15:16 by Hexperience.
17 Feb 2013 16:04 #6482 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 12S nightly
what is the battery alarm set at? what value do you see on the screen?
17 Feb 2013 23:50 - 17 Feb 2013 23:52 #6493 by Hexperience
With the older version it shows about 4.1v when I install newer version it shows about 3.8 or so. The alarm seems to be set at 4v by default? I have been installing the FS completely including the tx.ini.
I'm going give it a good charge and make sure it's 4.2 when I install again. I'll also try leaving the tx.ini and see what happens.
Last edit: 17 Feb 2013 23:52 by Hexperience.
18 Feb 2013 00:33 #6494 by Lasercopter
Replied by Lasercopter on topic Devo 12S nightly
So is deviation working with the devo 12s? fully functional? it doesn't say its supported and that is the only thing holding me from getting a 12s, please let me know.
18 Feb 2013 00:56 #6495 by Hexperience
Well as you can see it is still in testing but overall its looking very good.
18 Feb 2013 01:07 #6496 by Lasercopter
ok great im going to go ahead and purchase a devo 12s
Thank you guys.
18 Feb 2013 01:25 #6497 by PhracturedBlue
The default alarm is at 4V
The critical value was at 3.8V
On the devo12, it reliably reads down below 3.4V (as opposed to other Tx where it is unreliable below 4V) so I dropped the critical value to 3.5V.
I also recalibrated the tx so it should be accurate again after the updated scanning changes.
18 Feb 2013 01:44 - 18 Feb 2013 01:45 #6498 by Hexperience
Yes, running a tx on 1 cell was an odd choice. Makes it difficult to even add a module. Thanks fir the fixes PB.
Last edit: 18 Feb 2013 01:45 by Hexperience.
18 Feb 2013 03:12 #6501 by Hexperience
Firmware loads up fine now. Thank PB.
18 Feb 2013 07:33 #6504 by Lasercopter
so i finally ordered my Devo 12s, thank you PhracturedBlue for all your hard work, i will provide as much feedback as possible B) this is such a great tool.
22 Feb 2013 03:07 #6751 by Seabee92155
Replied by Seabee92155 on topic Devo 12S nightly
Man this is great! SamtheMan, I have just ordered my Devo 12s too. I am new to this site and have no idea on how to do the next step of installing the firmware. A minor detail I hope, These guys are great, I can't believe I am going to be able to have one transmitter flying multiple models with different receivers....yahoooooo! Good luck and hope it all works out.
27 Feb 2013 07:13 #7126 by Lasercopter
does anybody know if the full screen emulator for the Devo 12 would work with the 12s? i was reading of some people tweaking the screen of the 12.
  • rbe2012
  • rbe2012's Avatar
27 Feb 2013 08:27 #7127 by rbe2012
Replied by rbe2012 on topic Devo 12S nightly
Yes, Hexperience and I have done some work on it, but it is still experimental.
It works, but we are not that far to bring it in into the next release.
You can stay tuned here: Emulator for Devo12
02 Mar 2013 15:42 #7216 by Lasercopter
i finally received my devo 12s, the throttle stick came broken :( but i fixed it now it works great, now when i cant get it to go into DFU mode, I have it connected to my computer and its charging but when i press the EXT button and then turn it on it boots up normally, it does the same with the ENT button, im at a loss any suggestions?
Thank you
02 Mar 2013 15:47 - 02 Mar 2013 15:48 #7217 by vlad_vy
Replied by vlad_vy on topic Devo 12S nightly
If you take a look in DfuSe manual - Hold the DEVO-12’s TRN switch and keep it up,...
Last edit: 02 Mar 2013 15:48 by vlad_vy.
02 Mar 2013 16:03 #7219 by Lasercopter
Thank you, that worked
02 Mar 2013 16:24 #7220 by Lasercopter
now one last question, how do i get it into USB mode, not programing mode.
02 Mar 2013 17:39 #7221 by vlad_vy
Press 'ENT' and switch on Tx.
Time to create page: 0.170 seconds
