Devo 12S nightly
- Lasercopter
02 Mar 2013 17:48 #7222
by Lasercopter
Replied by Lasercopter on topic Devo 12S nightly
when i press ENT and the turn on the TX it boots up normally, no usb mode
Hardware V1.0
Software 1.4A
Library 1.0.8
Hardware V1.0
Software 1.4A
Library 1.0.8
02 Mar 2013 17:52 #7223
Replied by vlad_vy on topic Devo 12S nightly
USB mode works only with Deviation firmware.
- Lasercopter
03 Mar 2013 05:49 - 03 Mar 2013 05:49 #7260
by Lasercopter
Hello everybody here are some technical feedback now that i upgraded to Deviation.
-When I turn on the radio I get only 1 the picture of 1 helicopter, everything else is black with a blue edge.
-I cannot select anything.
-Once I press any button on the RX the picture of the heli disappears and i cant get it back.
-The touch screen does not respond.
-My upload file is from February 25th
I already tried to do the upload twice and restart it, every time with no error messages.
Im back with the normal walkera software.
Hardware ver 1.0
Software ver 1.4A
Library ver 1.0.8
Hardware ver 1.0
Software ver 1.4A
Library ver 1.0.8
Last edit: 03 Mar 2013 05:49 by Lasercopter.
03 Mar 2013 06:02 #7261
Make sure that you perform Devo 12 firmware upgrade right way:
www.deviationtx.com/forum/builds/1380-de...89f1f-devo12-support
- RCadik
03 Mar 2013 06:45 #7263
by RCadik
Replied by RCadik on topic Devo 12S nightly
I may be wrong about this, but I think part of his problem is scaling. At least that is what I discovered. I think Hexperience provided the correct scaling.
A good test for this condition, is to touch the screen about equal distance on the other side of the screen that the heli image is on. But..... keep in mind it's all quite new to me & the 12S.
Hope this helps.
Hope this helps.
03 Mar 2013 06:51 #7264
If you cann't call Tx settings screen and calibrate touch screen and sticks, press both 'EXT' and 'ENT'.
- Lasercopter
03 Mar 2013 07:27 #7267
by Lasercopter
finally got it to have the correct library, i cant select my models, how do i bind to an MSD2 plane? I couldnt get it to bind or is that not ready yet?
Thanks this is quite entertaining
03 Mar 2013 10:00 #7274
Replied by rbe2012 on topic Devo 12S nightly
Can you tell us something about your plane, esp. which receiver it uses?
In general, you have to choose the correct protocol on the model config page (where you can change name, icon and more), then the number of channels to use and maybe some other protocol options (depending ion the protocol) by touching the protocol button itself. After setting / clearing the fixed id you can press the button at the lower right (labelled bind, rebind or reinit in dependance to the protocol used).
You have to fulfill the needs of the receiver. Some will not bind with throttle > min or other conditions.
- Lasercopter
03 Mar 2013 14:33 - 03 Mar 2013 14:37 #7289
by Lasercopter
i have two UMX Gee Bee R2 and an Orange Rx R410
This model to be precise
www.e-fliterc.com/Products/Default.aspx?ProdID=EFLU4580
And this receiver
www.hobbyking.com/hobbyking/store/__1197...2_4Ghz_Receiver.html
Thank you for your help
And this receiver
Last edit: 03 Mar 2013 14:37 by Lasercopter.
- Lasercopter
13 Mar 2013 13:35 #7682
by Lasercopter
any help on how to bind this plane? sorry for the silly questions, i still dont fully understand how Ddeviation works
13 Mar 2013 16:02 #7691
Did you read the manual (look at "User Manual" in the left menu)? It should tell you how to bind.
I have some Blade helis (I think UMX is Horizon Hobby too so it uses DSM2/DSMX?) and some Orange RX610 which were bound easily as described in their manuals (bind plug for the RX610, special values for throttle and rudder for the helis - throttle down and rudder right, I believe).
- Wene001
30 Mar 2013 10:17 #8273
by Wene001
Replied by Wene001 on topic Devo 12S nightly
Is widescreen support implemented in the 12s nightly builds??
Greetz Werner
Greetz Werner
- Hexperience
30 Mar 2013 11:27 #8277
by Hexperience
Replied by Hexperience on topic Devo 12S nightly
No, wide screen is experimental. rbe2012 has a repository in which he pulls from the official deviation repo, and that has wide screen support, real time clock etc. It will be awhile before PB looks at all the code and then if everything looks good he'll pull those changes into the main repo.
- glider
03 Apr 2013 11:16 #8447
by glider
Replied by glider on topic Devo 12S nightly
HI
When You think that Devo 12S while work with DSM2???
03 Apr 2013 11:35 #8452
The next coming version will do that. DSM2 is already supported and the 3.0 will support Devo12S.
The nightly builds do support both already.
- oso
28 Apr 2013 21:33 #9325
by oso
To crash is to take one step forward...
Replied by oso on topic Devo 12S nightly
Finally I can go and buy my devo 12. You guys are absolutely amazing. Beeing from sweden I say. Give the Noble price to the deviation team!!!
thanks for all the hard work! forever in debt...
Tomas
Sweden
Tomas
Sweden
- omija
30 Apr 2013 07:37 #9375
by omija
Replied by omija on topic Devo 12S nightly
really can not find where i can download a binary package of wide-fullscreen build for devo12....
so i am still using the firmware coming with my tx.
Time to create page: 0.392 seconds
- Devo 12S nightly
