6 mode switch hardware mod for multi's <?>
- wavezz2k
24 Dec 2013 01:32 #16961
by wavezz2k
6 mode switch hardware mod for multi's <?> was created by wavezz2k
Not pressing, but this would be helpful for multirotor. haven't looked inside recently, but this seems do-able for the 8s. Any reason this may not work on the 8s, before I mangle things ?
6 position potentiometer with trims, ideal for modes toggle on multirotor -
www.ebay.com/itm/UNIVERSAL-Mode-switch-6...sd%3D161120022696%26
- Pattaya01
24 Dec 2013 01:43 - 24 Dec 2013 01:51 #16962
by Pattaya01
Replied by Pattaya01 on topic 6 mode switch hardware mod for multi's <?>
It is very easy to get 6 flight modes with 2 switches using the mixer.
www.deviationtx.com/forum/3-feedback-que...t-mode-setting#11435
and
www.deviationtx.com/forum/3-feedback-que...t-mode-setting#12544
and
Last edit: 24 Dec 2013 01:51 by Pattaya01.
24 Dec 2013 08:46 #16967
Replied by rbe2012 on topic 6 mode switch hardware mod for multi's <?>
This is a multi-position-switch which gives out different resistor values (configurable with the pots). To use it, you will need a ADC input pin - as far as I remember there is no such pin easily available (only with some hard soldering directly at the MCU pin).
Time to create page: 0.081 seconds
- 6 mode switch hardware mod for multi's <?>
