6 mode switch hardware mod for multi's <?>
24 Dec 2013 01:32 #16961 by wavezz2k
Not pressing, but this would be helpful for multirotor. haven't looked inside recently, but this seems do-able for the 8s. Any reason this may not work on the 8s, before I mangle things ?
6 position potentiometer with trims, ideal for modes toggle on multirotor -
www.ebay.com/itm/UNIVERSAL-Mode-switch-6...sd%3D161120022696%26
24 Dec 2013 01:43 - 24 Dec 2013 01:51 #16962 by Pattaya01
Last edit: 24 Dec 2013 01:51 by Pattaya01.
  • rbe2012
  • rbe2012's Avatar
24 Dec 2013 08:46 #16967 by rbe2012
Replied by rbe2012 on topic 6 mode switch hardware mod for multi's <?>
This is a multi-position-switch which gives out different resistor values (configurable with the pots). To use it, you will need a ADC input pin - as far as I remember there is no such pin easily available (only with some hard soldering directly at the MCU pin).
Time to create page: 0.050 seconds
