Newbie's questions about adding switches to the 7e
- Khan
- Build. Crash. Repeat.
20 May 2014 09:29 #23392
by Khan
Newbie's questions about adding switches to the 7e was created by Khan
Hi Guys !
I'd like very much to add switches to my 7e.
I've read this thread Adding custom switch support in Deviation but I can't understand everything that is at stake there.
So I have a few questions :
1. Can I add 2 3-way switches to my 7e while keeping the existing Hold and Fmode switches functional ?
2. If I understand correctly, the additional switches work with diodes. When I go to the electronics shop, what kind of diodes should I ask for ?
3. I don't remember having seen any wiring scheme. Any info on that, or a close look at Galee's pictures is sufficient ?
4. Does the official Deviation 4.0.1 release support the additional switches yet ? If not, which build I should download & install ?
Thanks !
Thanks !
- IMback!
20 May 2014 13:42 #23397
by IMback!
Replied by IMback! on topic Newbie's questions about adding switches to the 7e
1. yes
2. dose not matter (within reason any non led diode should work and LEDs might work too.)
3. I don't know if there is a diagram somewhere.
4. no the latest nightly should do the trick. if stability is a concern I can build you a 4.0.1 with the 2x2 patch applied
- yidc
20 May 2014 15:46 - 20 May 2014 15:46 #23401
by yidc
Replied by yidc on topic Newbie's questions about adding switches to the 7e
including custom-switch support in Deviation
FYI, you may refer to the above link for detail wiring scheme.
Last edit: 20 May 2014 15:46 by yidc.
- Khan
22 May 2014 08:03 #23494
by Khan
Replied by Khan on topic Newbie's questions about adding switches to the 7e
Thanks guys !
Time to create page: 0.033 seconds
- Newbie's questions about adding switches to the 7e
