Voice alerts test build
- Moeder
03 May 2017 19:30 #61966
by Moeder
Replied by Moeder on topic Large voice pack in EN available for download
Roughly based on OpenTX Amber voice I generated a voice set with 155 custom messages. It is available for download
here
Please note the current build is limited to 240 mp3 files, of which 150 are already used by global alerts, numbers and units. The next nightly build will have this limit increased to 400.
- magic_marty
04 May 2017 05:12 #61984
by magic_marty
Replied by magic_marty on topic Large voice pack in EN available for download
Great! unfortunately i can't get my dang mk tool to work again so i guess i'll have to wait for the nightly build ..
04 May 2017 14:13 #61989
Replied by mwm on topic Voice alerts test build
Has anyone tried the Taranis speaker?
www.banggood.com/FrSky-Taranis-X9E-Speak...76.html?rmmds=search
- justyn07
04 May 2017 15:32 #61994
by justyn07
Replied by justyn07 on topic Voice alerts test build
does someone have a devo 10 with the install guide.
- bartasdiver
04 May 2017 20:28 #62007
by bartasdiver
Replied by bartasdiver on topic Voice alerts test build
I'm also considering buying one, does anyone know the thickness?mwm wrote: Has anyone tried the Taranis speaker? www.banggood.com/FrSky-Taranis-X9E-Speak...76.html?rmmds=search
- magic_marty
05 May 2017 05:44 #62016
by magic_marty
Does the 5-4-17 nightly have the latest updates to the voice alerts?
Moeder wrote: Roughly based on OpenTX Amber voice I generated a voice set with 155 custom messages. It is available for download here .
- magic_marty
06 May 2017 03:24 #62053
by magic_marty
The voice alerts not working with the latest nightly..I installed it and now if i select the voice config is says "External voice not available"
I formatted ect...like always and replaced the mp3 file on the SD card but still no joy..
Does the library.dfu on the nightly include to voice.ini ?
- magic_marty
06 May 2017 03:36 #62054
by magic_marty
So i generated a library.dfu and i get voice alerts but they are retarded ..i only have 2 i can select one is "3D robotics" and the other is "timer reset"...When i adjust the volume it says "Throttle" also instead of finished binding it says "Throttle" ..When a timer expires it says "Throttle low waypont seconds"
- Moeder
06 May 2017 22:54 #62074
by Moeder
I didn't check with the emulator to be honest, I will look into it when I get back home...
- Deal57
13 May 2017 15:44 #62275
by Deal57
I have also not been able to get the new Large Voice Pack MP3 folder to work (posted on 5/3). I just updated the nightly to the 5/10 release, deviation-devo12e-v5.0.0-31fcd0d, added the new voice.ini and copied over the MP3 folder to my dfplayer chip. When I try to select a sound for the switches the selector show the entry for 201, but then 0, and those are the only choices for any of the switches... I didn't try any other sounds. I replaced the MP3 folder and voice.ini with the working ones from 3/16
and they appear to work.
Have your updates for more sound files been included in the new nightlies?
- Deal57
13 May 2017 16:19 #62277
by Deal57
I found a source for small Micro SD cards that are pretty perfect for the voice files.
This microSD chip
is 128MB, and since the MP3 folder total size is under 2mb, it's more than sufficient for an internal sound board.
- Moeder
13 May 2017 18:56 #62280
by Moeder
You are right, I did the voice pack without testing....shouldn't do that, but I was lazy
Next nightlies should work fine, at least it does in the emulator.
- Moeder
14 May 2017 08:23 #62295
by Moeder
Now for some documentation...I added a quick Wiki entry
www.deviationtx.com/wiki/voiceoutput#wiring_diagram
Now for the manual...
- magic_marty
14 May 2017 09:36 #62296
by magic_marty
I noticed the 5-14-17 nightly build is available does it contain the fix to the voice alerts?
- Moeder
14 May 2017 10:47 #62297
by Moeder
Yes, 2017-05-14 has the fix.
magic_marty wrote: I noticed the 5-14-17 nightly build is available does it contain the fix to the voice alerts?
- magic_marty
16 May 2017 04:31 #62339
by magic_marty
Latest nightly works but don't use the Library.dfu it doesn't contain the voice.ini i had to regenerate another one to get the voice alerts working...Is there any plans in the future for the library.dfu files to already have the voice.ini mapping included or are we going to have to regenerate them each time there is a new voice.ini update?
- pulpfiction15
16 May 2017 07:29 #62343
by pulpfiction15
Magic_marty, I fully adhere to the idea, including a 'default' voice.ini, would help.
For the moment I am hesitating to load other nightly versions, because of the this.
I am flashing the latest nighlies with a Linux PC, and then have to dig out a Windows PC to generate the librery.dfu
- Fernandez
16 May 2017 11:59 #62352
by Fernandez
Replied by Fernandez on topic Voice alerts test build
Hi guys this is getting a very lengthy read;
Is it possible to edit update, the first post of this topic, with the latest instructions / how to setup?
So anyone could more easily start into beta testing and using voice?
- justyn07
16 May 2017 12:58 #62355
by justyn07
i second what you said.
- Deal57
16 May 2017 13:11 #62356
by Deal57
There is a WIKI page in process, and I will add my notes. There are two elements to address, I think, first how does the hardware connect, and second how do you add the functionality to your Devo software. If you can think of any specific questions, or additional categories, please add them here!
Time to create page: 0.904 seconds
Builds
- Voice alerts test build
