Jumper T8SG builds
25 Oct 2017 06:47 - 27 Oct 2017 03:53 #65252
Summary of changes from stock T8SG:
* RUD and AIL reversed to comply with common direction for Deviation.
* Rotary knobs (AUX4 and AUX5) direction reversed to comply with common direction for Deviation.
* All four switches SWA, SWB, SWC and SWD reversed to comply with common direction for Deviation.
* Fix switch mapping for foreign model files.
Current changes:
* Fix min/max limit values on LRSSI so alarm can be set on LRSSI, from hexfet
T8SG based on devo7e-256 Nightly Builds:
File deleted, see below...
Replied by vlad_vy on topic Jumper T8SG builds
Current changes:
Last edit: 27 Oct 2017 03:53 by vlad_vy.
- Iroquois
25 Oct 2017 16:47 - 25 Oct 2017 16:49 #65261
by Iroquois
Replied by Iroquois on topic Jumper T8SG builds
You have to create 30 blank model.ini files, label them 31 to 60 and then paste them into the 'Model' folder. If you label them anything else it will not accept them.
Last edit: 25 Oct 2017 16:49 by Iroquois. Reason: spelling correction
- gvhlaw
25 Oct 2017 16:56 #65262
by gvhlaw
Replied by gvhlaw on topic Jumper T8SG builds
Vlad - am I correct in understanding that I do not need to copy my configured model.ini files back after flashing the latest build? Also, no need to save and copy back the TX.ini and Hardware.ini? Previously flashing a new nightly build would wipe-out my models and I had to copy TX.ini and Hardware.ini back in order to preserve my Devo 7e hardware setup with the NRF and A7105 chips. Thanks!
25 Oct 2017 21:57 #65267
Replied by mwm on topic Jumper T8SG builds
You should always back up the TX file system before upgrading. Flashing new firmware should not destroy your config files. But that's also true for the 7e, so whatever is causing you to do that on the 7e may cause the same problem on the T8SG
- gvhlaw
26 Oct 2017 00:02 #65274
by gvhlaw
Vlad - I flashed your new T8SG build to my transmitter and promptly lost range with two different quads. They fell out of the sky at about 30-40 meters distance. I reverted to the 10/11/17 build and all is well. I copied over my tx.ini and hardware.ini files - don't know how that could have caused a problem other than stick calibration.
26 Oct 2017 04:18 - 26 Oct 2017 05:23 #65279
I don't know why it cood happened. Last builds change some protocols only. You don't need rewrite the filesystem, since it doesn't changed. You can flash the firmware file only.
If you write into the filesystem, safely remove USB drive before disconnect, otherwise files can be damaged.
Try flash the last build and do not touch filesystem.
Last edit: 26 Oct 2017 05:23 by vlad_vy.
- Moeder
26 Oct 2017 08:02 #65280
by Moeder
Replied by Moeder on topic Jumper T8SG builds
Which protocols are the affected quads using?
- gvhlaw
26 Oct 2017 15:35 #65281
by gvhlaw
It was the protocol for the JJRC X1 and Tarantula X6 - but I have done as Vlad suggested and just flashed the new firmware - will do a test fly and let you know what happens.
- gvhlaw
- watchthis1993
27 Oct 2017 00:39 #65288
by watchthis1993
Replied by watchthis1993 on topic Jumper T8SG builds
This is a great little radio. Only problem is I cannot get elevon mixing to work on it. If someone could please make me a template for a flying wing I would appreciate it...YES I KNOW, THERE IS A SEARCH BAR, none of the templates on this forum work I have literally downloaded them all. My channels are as follows 1 = Ail 2 = Ele 3= Thr 4 = Rud
I have watched videos on trying to make my own it simply doesn't work for me I'm certain it is something simple I'm missing. Thanks for your time ahead of time.
- watchthis1993
27 Oct 2017 01:10 #65291
by watchthis1993
If someone could steer me in the right direction with this issue. I just got one of these radios.it works great. i fly many planes from .15- 1.60 sized glow. i have about 6 flying delta wings...id love to fly them again, its just...well, i cant get the elevons to mix. its great that i can bind to any receiver i want, and sit in my basement and work my servos on whatever protocol I wish. But i would like to fly in the next 7-10 years. So if you all could save me some time and write me a template i would appreciate, i do not want this on a switch. I just want a simple elevon set up. here is my radio setup. for your use, thanks ahead of time for you paitience. im sure its something simple i am missing
Ch1- Ail
Ch2- Ele
Ch3 - Thr
Ch4- Rud
Also...
1. I know theres a search button
2. I know many of you have already written Elevon mixes
3. They dont work for me for some reason,
4.Thanks
Ch1- Ail
Ch2- Ele
Ch3 - Thr
Ch4- Rud
Also...
4.Thanks
27 Oct 2017 03:50 - 05 Nov 2017 09:00 #65295
Current changes:
* Improve voice startup and shutdown message timing and fix FrSkyX serial port handling, from TheRealMoeder
Current changes:
Last edit: 05 Nov 2017 09:00 by vlad_vy.
- Iroquois
27 Oct 2017 08:55 #65297
by Iroquois
Whatever you're missimg, I'm missing it too. I can't get a V-tail to work.
27 Oct 2017 09:32 - 27 Oct 2017 09:49 #65298
We can only discuss something specific, psychics are not here. If you will attach or even better link to a specific template, we can look why it does not work for T8SG. Also will be nice if you report firmware version (stock or custom).
Last edit: 27 Oct 2017 09:49 by vlad_vy.
- Iroquois
27 Oct 2017 10:54 - 27 Oct 2017 10:55 #65299
by Iroquois
Specifically, how do you mix one channel with another? Devo or JUMPER.
Last edit: 27 Oct 2017 10:55 by Iroquois. Reason: spelling
27 Oct 2017 11:34 #65300
Mixer with two pages: 1) Src=ELE, Scale=60, Mux=replace, 2) Src=RUD, Scale=60, Mux=add
27 Oct 2017 11:35 #65301
A v-tail mix (actually, any fixed wing model type) requires the advanced mixer.
To mix two inputs together, use a complex mix type with at least two mixers. The first mixer should use one of the inputs as an input with a mux of replace, no switch, and whatever curve type you want.
The second should use the other input, mux of "add", a switch if desired, and again the curve type you want.
Set the scale on both as appropriate.
There have been a number of templates for various fixed wing types posted. You might see if you can find those in the forums.
- Iroquois
27 Oct 2017 12:44 #65302
by Iroquois
Many thanks for that. As a matter of interest, I hope you guys aren't wasting your time but my JUMPER uses my Devo 7e model.ini files and everything works in the right direction. It also has the USB port accessible via the battery hatch.
- zarni
27 Oct 2017 12:51 - 29 Oct 2017 13:37 #65303
by zarni
"I got Elevons to work on the T8SG with this one simple trick!"
Actually it took me a while but I did get it.
I am happy to share everything however I don't want to derail the builds thread too much,
so if you're up to posting in the T8SG thread in the Deviation forums or on RCgroups I'll follow up there.
Replied by zarni on topic Jumper T8SG builds
watchthis1993 wrote: This is a great little radio. Only problem is I cannot get elevon mixing to work on it. If someone could please make me a template for a flying wing I would appreciate it...YES I KNOW, THERE IS A SEARCH BAR, none of the templates on this forum work I have literally downloaded them all. My channels are as follows 1 = Ail 2 = Ele 3= Thr 4 = Rud
Last edit: 29 Oct 2017 13:37 by zarni.
- SeByDocKy
29 Oct 2017 06:06 #65336
by SeByDocKy
Replied by SeByDocKy on topic Jumper T8SG builds
Is the fix for FlySky AFHDS integrated in the last build ?
Time to create page: 1.071 seconds
Builds
- Jumper T8SG builds
