Jumper T8SG builds
- Vino
25 Jan 2018 06:40 #67145
by Vino
Thanks for your help, Vlad, it's MUCH appreciated. Yeah, I saw your response on rcgroups to my thread so I responded there so we're not chatting between both groups.
I THINK I calibrated it properly but, this is my first radio and I've never seen it done, so.. But I explained what I did in the rcgroups thread if you're able to take a look at that and check.
Replied by Vino on topic Jumper T8SG builds
vlad_vy wrote: It can be improper calibration (don't forget calibrate knobs along with sticks) or AIL pot connection to mainboard problem.
- fneuf
30 Apr 2018 12:23 - 30 Apr 2018 12:24 #68936
by fneuf
Replied by fneuf on topic Jumper T8SG builds
I just updated to 2018-04-28 from 2017-11-07, I'm surprised I don't see anymore the version date on the bootscreen. I now see what I believe to be the build number "9864d0d".
If I upgrade with latest 5.0.0 this version/date is then blank on bootscreen and also in the "About Deviation" menu.
Is this behavior normal ?
Last edit: 30 Apr 2018 12:24 by fneuf.
01 May 2018 05:29 #68947
Replied by vlad_vy on topic Jumper T8SG builds
Initially T8SG based on Nightly Builds.
If you will update to Nightly builds you will see the build number.
If you will update to "Deviation v5.0.0 build with latest protocols" you will see the v5.0.0 build date. Also, you need rewrite filesystem, since it's different from Nightly builds.
- chbronco
05 Jun 2021 02:49 #77420
by chbronco
Replied by chbronco on topic Jumper T8SG help
Someone stepped?and broke the right gimbal the pitch one I can fix it .but for the life of me I can't figure out how the spring goes back in .Seen some pics the pitch spring hooks on the bearing holder but what does it hook to any help? This is the 1st gen jumper t8sg.
Time to create page: 0.173 seconds
Builds
- Jumper T8SG builds
