How to upgrade Devo TX to Deviation Firmware
04 Jan 2014 17:34 #17932 by Tom Z
FDR,
I just downloaded V4.0.1. My "How to video" on page one of this thread will be
different for V4 when it comes to the part to copy files over to the transmitter. The files and folders for V2.1 and V3 are going to be different for V4 I see. Also there is no "File System folder".
I am going to edit my video description to list the video is for V2.1 and V3.
Maybe I can make another "How to video" for V4 once I figure out how to do it myself (which files to copy over). Or just edit the current video and add in a video on which files to copy over to the transmitter for V4 assuming all the other procedures are the same from start to finish.
04 Jan 2014 17:44 - 04 Jan 2014 17:45 #17935 by PhracturedBlue
Replied by PhracturedBlue on topic How to upgrade Devo TX to Deviation Firmware
Please check the new 4.0 users manual. It should document the procedure better than previous versions did. It is hopefully a good reference for making a video
Last edit: 04 Jan 2014 17:45 by PhracturedBlue.
04 Jan 2014 18:41 #17943 by Tom Z
I just downloaded the V4.0 users manual.
The screen shot shows which files/folders to copy over. I will try it out when I get a chance.
Is it OK with you if I show the sections "2.1 New installation" and "2.2 Upgrade notes" in my video also?
Thanks.
04 Jan 2014 23:53 #17956 by wavezz2k
Howdy, I have a DeviationTX v0.8 Older Devo8 (upgraded to 8s) that just flashed to 4.01 using XP, and a newer 8s with 3.0 that am going to go to 4.01 also. I find the new documents and S/W dev to be first rate. Many thanks.
I have the driver issue that other Win7 folks noted, and also agree, this:
image.helipal.com/helipal-devo8-update-firmware-big-1.jpg
is a fairly nice reference.
Loading DevoDfuSe 2.0 installs 32b XP no hickup, all fine. But on Win7 64b, the driver does not load, and even attempting a manual driver install, by pointing to the directory
C:\Program Files (x86)\DeventionTX Upgrade Tools\Driver
Neither X86 nor X64, Appears to work. Both cases, 'driver not found', though .SYS file is present.
Doubt this is a factor, but note that this Dell XPS 15z has a STmicorelectonics fall sensor (accel).
If this is answered elsewhere, prior, my apologies.
Any suggestion, or thoughts appreciated.
05 Jan 2014 10:02 #17976 by RandMental
Replied by RandMental on topic How to upgrade Devo TX .. (Win7 64b driver fails)
It is probably the old USB issue, see if you can remove all USB devices, reboot with only the Devo TX connected to USB. Most of the times that would allow the driver to be installed, there after you can connect other USB devices again.
06 Jan 2014 00:04 #18031 by Tom Z
FDR,
I just made a Step by Step How to Video on upgrading the Devo Transmitter firmware to the Deviation Firmware V4.
Can you edit your first post in this thread and insert what I posted below the line? You can copy and paste it. If needed you can edit my post so you can access the YouTube links.
I added the new video to my web site also where I have the first video posted.
Videos made by: Tom Z
How to upgrade Devo Tx Firmware to Deviation Firmware V2.1 and V3
How to upgrade Devo Tx Firmware to Deviation Firmware V4
06 Jan 2014 01:23 #18032 by PhracturedBlue
Thanks Tom. I updated the 1st post.
23 Feb 2014 19:06 - 23 Feb 2014 19:07 #20797 by carlnoki
Replied by carlnoki on topic How to upgrade Devo TX to Deviation Firmware
I was watching the NASCAR pre race program and decided to go ahead and try the deviation update.
I have the DEVO 10 system and in less than about 15 min. it was finished.
I was apprehensive but thought what the heck. WORKS GREAT!!!!!!!!!!!!!!!!!!
now I do not have to haul out 3 different transmitters to the field when I go flying.
You folks have provided a great service and product to us folks in the hobby/sport.
keep up the great work guys.
Carl
Last edit: 23 Feb 2014 19:07 by carlnoki.
23 Feb 2014 21:58 #20809 by carlnoki
been re-setting up a couple models with DEVO protocal.
learning the new menu layout and how it works.
not bad at all. I like it. :-)
also bound one of my orange receivers to the DEVO 10TX and figured out how to do that. very easy actually. now, I just have to remember how I did it. LOL
Hey, at 60, the first thing to go is the memory, right? LOL
Carl
25 Feb 2014 20:41 #20868 by Blayd
OK.. have a problem.
I went to revert back, one of my 8S devo from v4 and went through upgrading the stock firmware and library, and now my screen is all screwed up. Unreadable. Any idea of what I did wrong and how to fix this?
Devo 8S
Trex500ESP
Trex500ESP (Belted tail)
HC500SE
Trex700N2E
25 Feb 2014 20:56 - 25 Feb 2014 20:59 #20869 by Blayd
I went and reloaded v4 again, but lost the model I had in it. I wanted to make sure I could get the Tx back working.
OK, so why wouldnt it upgrade back to the stock firmware? Thanks for any help.
Do I need to go in, delete all of the files from v4 and reformat the drive before trying to put the stock firmware back?
Devo 8S.
Defuse tool 2.0
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
Last edit: 25 Feb 2014 20:59 by Blayd.
  • rbe2012
  • rbe2012's Avatar
02 Mar 2014 14:05 #21078 by rbe2012
Replied by rbe2012 on topic How to upgrade Devo TX to Deviation Firmware
No, shouldn't be necessary. But remember that you have to flash firmware AND library of the stock firmware (other than deviation: uses only firmware and presents the library store for USB - re-flashing the library destroys the USB drive content).
02 Mar 2014 17:17 #21091 by Blayd
Yeah, thats what I originally did. Flashed the stock firmware and Lib back, restarted and the screen is all messed up.
I have 2 Devo 8S tx's and a Devo 8 that were running Deviation v4, so I took the Dev8, went back into USB mode, deleted all the files, then ran the Defuse updater, and reflashed the stock firmware back into the Devo 8, and it seemed to work.
I havent gotten to try it on the Devo8S yet.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
25 Mar 2014 17:24 - 25 Mar 2014 17:31 #21831 by diy
Overview, why and how to upgrade Devo Tx to Deviation 4.
Last edit: 25 Mar 2014 17:31 by diy.
12 Jun 2014 09:14 #24049 by D_an_W
Followed the guide in the first post and my shiny new Devo 7E is now rocking the latest nightly build...thanks!
Now to find a beginner profile for this Super CP I was just bought for my birthday!
05 Jul 2014 15:31 #24399 by Sputnik
Replied by Sputnik on topic How to upgrade Devo TX to Deviation Firmware
Hi everyone,
I just bought Walkera QR X350 pro and updated firmware on 4.0.1
Now don't have any controls at all
Can someone help me and explain how to bring back factory firmware and insert best setting for parameters.
05 Jul 2014 15:35 #24400 by ave1
4.01 is bullet proof. I don't know quads but Please give some info. TX, etc. did it bind?
09 Aug 2014 17:40 #25113 by Face73
Hi!, all i just brought Devo 10 and i'm going to upgrade to deviation software. Could i upgrade lastest version immediately or need to upgradestep by step from version 1,2,3,4 ? thank you in advance.
09 Aug 2014 18:10 #25114 by TomPeer
Replied by TomPeer on topic How to upgrade Devo TX to Deviation Firmware
you can go to the latest version immediatly, or even straight to the nightly build if you want.
Have fun
24 Dec 2014 07:20 #27192 by cantflyby
Replied by cantflyby on topic How to upgrade Devo TX to Deviation Firmware
Hello everyone, i have installed the nrf24L01 module and was wondering if there is a vid or tutorial on how to change the files so this module will work.
I am a computer dummie and am clueless when it comes to that stuff.
Time to create page: 0.155 seconds
