Walkera QR Ladybird accelerometer calibration
03 Jan 2013 12:16 - 03 Jan 2013 16:28 #4572 by vlad_vy
You must set the trimmers in Tx to neutral, release the fixed ID, perform auto-bind, and then a test flight. If quadrocopter drifts forward, put a couple of sheets of paper under the front legs, repeat the auto-bind. The same applies to any other direction. It is desirable to achieve minimal drift with zero ​​trimmers. After obtaining a satisfactory result, the last time perform auto-bind on selected sheets of paper and then immediately bind with a fixed ID.
Last edit: 03 Jan 2013 16:28 by vlad_vy.
03 Jan 2013 12:21 #4574 by FDR
:blink:
I don't have any trouble with mine, simply using the trims if needed, however I don't use it to hover in place...
03 Jan 2013 12:32 - 03 Jan 2013 12:40 #4575 by vlad_vy
Replied by vlad_vy on topic Walkera QR Ladybird accelerometer calibration
It's started from the case when I tried to compensate rotation by rudder trimmer. After every auto-bind I needed again and again compensate rotation in one drection. When I realized that I have trimming with value 3% of channel travel, I understand that something is wrong. Auto-binding compensate/zeroize any existing trimming.
Last edit: 03 Jan 2013 12:40 by vlad_vy.
03 Jan 2013 12:34 #4577 by FDR
vlad_vy wrote: ...
...of all, or just the rudder?
BTW I use it with fixed id...
03 Jan 2013 12:39 #4578 by vlad_vy
With Fixed ID you have not this problem.
Now, after accelerometers calibration and then setup Fixed ID, I almost haven't drift at any direction (and rudder also), with zero trimmers in Tx.
03 Jan 2013 13:15 #4583 by FDR
Then I'm just lucky, I guess! ;)
03 Jan 2013 14:02 #4592 by vlad_vy
vlad_vy wrote: When I realized that I have trimming with value 3% of channel travel, I understand that something is wrong.
This is why I requested digital value of trimmers at main screen. I was able to see this abnormal value only at channel monitor.
18 Jan 2013 09:17 #5143 by Morlacus
Replied by Morlacus on topic Walkera QR Ladybird accelerometer calibration
I have a QR ladybird and a Devo 8s. I need a subtrim forward of 10 % approx to have a correct flight.
Is the method of calibration you propose possible whith the deviation software or also with the standard soft ?
What is the function of the sheets of paper in the process ?
Thanks for your reply
Morlacus
18 Jan 2013 09:53 - 18 Jan 2013 09:53 #5144 by vlad_vy
It's works with any firmware. Sheets of paper serves for leveling QR Ladybird in time of calibration.
Last edit: 18 Jan 2013 09:53 by vlad_vy.
18 Jan 2013 12:22 #5146 by Morlacus
Hello Vlad_vy
Thanks a lot for your fast reply. I tried the process but had no success (no change at all) even when puttig the legs of the ladybird on a rather hight step (1 cm). But may be I dont understand what you mean by "perform auto-bind" . Is it more than switching the LB on and the TX on and waiting for the binding ?
Best regards
Morlacus
18 Jan 2013 12:30 - 18 Jan 2013 12:31 #5147 by vlad_vy
Auto-bind = without Fixed ID. I'm not 100% confident that this process works, but it helps me. Possible you have other problem, 10% of trim it's a lot.
I used at most 6 sheets of paper.
Last edit: 18 Jan 2013 12:31 by vlad_vy.
06 Aug 2013 20:16 #12794 by SilbernerSurfer
Replied by SilbernerSurfer on topic Walkera QR Ladybird accelerometer calibration
I have the same problem! No diferrence about calibration with auto-bind.
I put the backarms of the Ladybird on a 1 cm step. No difference.
I am using a Devo 7e out of the box, no firmware.
Are there any other settings which i have to pay attention?
LED red or green for example?
It is my first Ladybird and my first Devo 7e. Just one day old. :-)
Please, can you make a step by step explanation of this Procedure about accelerometer calibration and IP-binding?
Best regards Uwe
07 Aug 2013 05:32 - 07 Aug 2013 05:37 #12800 by vlad_vy
1. Clear Ladybird Fixed ID with bind plug.
2. Reset all Tx trims and subtrims to zero.
3. Place Ladybird on perfectly level surface.
4. Switch on Tx and (in 10 sec) connect flight battery to Ladybird. Wait auto-bind and initialization (solid red LED).
5. Perform test flight.
6. If Ladybird drifts forward, place a couple sheets of paper under the front legs, repeat steps 4 and 5. The same applies to any other direction. It is desirable to achieve minimal drift with zero ​​trimmers.
7. After obtaining the satisfactory result, the last time perform auto-bind on selected sheets of paper and then immediately bind with a Fixed ID.
If you have any unusual Ladybird behaviour, clear Ladybird Fixed ID with bind plug. Usually it helps.
Last edit: 07 Aug 2013 05:37 by vlad_vy.
08 Aug 2013 06:05 - 08 Aug 2013 06:12 #12832 by SilbernerSurfer
I have asked my dealer about calibration of the accelerometer of the Ladybird.
He says there is no possibility to calibrate it.
Maybe he is right.
I have tried auto-bind and fixed id binding.
Nothing has changed.
Only trimming is possible in my case.
From where did you get the information about calibrating?
Last edit: 08 Aug 2013 06:12 by SilbernerSurfer.
08 Aug 2013 06:21 - 08 Aug 2013 06:24 #12833 by vlad_vy
I discovered it by self. For me, with two QR Ladybird v1 it works. Trimming with auto-bind mode is useless, it can be used with Fixed ID only.
Possible QR Ladybird V2 has other behaviour, but I have not V2.
Last edit: 08 Aug 2013 06:24 by vlad_vy.
Time to create page: 0.109 seconds
