Walkera 4G3
- Joshua
25 Dec 2012 22:30 #4266
by Joshua
Walkera 4G3 was created by Joshua
Need a working .ini file for Walkera 4G3.
Tried myself, but pitch did not work.
- Fernbediener71
03 Jan 2013 15:31 #4618
by Fernbediener71
Replied by Fernbediener71 on topic Walkera 4G3
Hi!
I did a basic setting for the 4G6, it should work with the 4G3, please test it.
- Joshua
03 Jan 2013 17:05 #4626
by Joshua
Replied by Joshua on topic Walkera 4G3
Thanks for you .ini file.
I testet it, but same problem as my own file. Pitch did not work.
May be a general problem with WK2601 mode or RX2605?
ciao, Bernd
ciao, Bernd
03 Jan 2013 18:08 #4627
Replied by rbe2012 on topic Walkera 4G3
Did you try the different modes for WK2601 (click on it, you get to channel mode). I do remember a little bit that I had a similar issue with RX2604 but I have thrown the config away...
- domcars0
03 Jan 2013 18:23 #4628
by domcars0
Replied by domcars0 on topic Walkera 4G3
Probably the Col Limit is set to 0 in the Channel mode of your WK2601 protocol...
- Fernbediener71
03 Jan 2013 20:29 #4631
by Fernbediener71
I have the RX2609 in the 4G6...
Try to use the 2801 mode with 6 ch.
- Joshua
03 Jan 2013 20:51 #4635
by Joshua
2801 mode did not bind.
I have a RX2605 and not a RX2605A
- blackmoon
04 Jan 2013 00:39 - 04 Jan 2013 01:16 #4640
by blackmoon
Replied by blackmoon on topic Walkera 4G3
If I remember correctly RX2605 was known for having trouble even with the 2801.
But don't take my word for granted, it was a long time ago.
Walkera mojo as always
I'll try to confirm by digging the old 4g3 thread on Rcgroups, but it will take some time.
Edit:
Found something but don't know if related.
See post #520 and following posts until #528
www.rcgroups.com/forums/showthread.php?t=984787&page=35
You can find here a setup for a 4g3 (2605 RX) in 2601 mode on the 2801 (#2 post)
rcfriends.createforumhosting.com/2801-combo-settings-t228.html
I know there is more information scattered on the 4g3 and "new" 4g3 threads on RCG, you'll have to search them... time to go to bed
Edit:
Last edit: 04 Jan 2013 01:16 by blackmoon.
Time to create page: 0.098 seconds
Model Configs
- Walkera 4G3
