blade 120sr config?
- quikster
28 Dec 2012 15:49 #4322
by quikster
blade 120sr config? was created by quikster
does anyone have a working blade 120sr config.
- coaster
28 Dec 2012 17:18 #4325
by coaster
Replied by coaster on topic blade 120sr config?
here we are ...
cheers
Coaster
cheers
Coaster
- quikster
- quikster
28 Dec 2012 17:36 #4327
by quikster
Replied by quikster on topic blade 120sr config?
is the type supposed to be a plane or does it even matter?
- sbstnp
28 Dec 2012 18:03 #4328
by sbstnp
Type only matters if you do CCPM on the TX. 120SR is a FP flybarred so no CCPM.
But, it is safe to change it to heli, even if it doesn't matter, just to be semantically correct.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic blade 120sr config?
quikster wrote: is the type supposed to be a plane or does it even matter?
Devo 10 + 4in1
- quikster
28 Dec 2012 18:57 #4330
by quikster
Is it just not supported with other protocols?
Thanks. what about throttle hold? i've tried to play around with the settings and compared them to other settings like Tomz's minicp settings which has a working throttle hold but i can't seem to get it to work on the 120 regardless of what i do.sbstnp wrote:
- sbstnp
28 Dec 2012 19:02 - 28 Dec 2012 19:03 #4331
by sbstnp
Again, TH has nothing to do with the protocol, but with the Throttle channel itself.
On Devo10, I do this:
1. Go Model setup/Mixer
2. Select THR channel
3. Select from Safety entry a switch to act as TH.
4. Make sure Safety value is -100.
Done.
Should be similar on the 8 or 6, maybe easier.
I really recommend that you read the manual, even multiple times if needed, you will be doing yourself a favor.
Devo 10 + 4in1
Spektrum Dx9
Done.
Devo 10 + 4in1
Last edit: 28 Dec 2012 19:03 by sbstnp.
- Joshua
28 Dec 2012 19:05 - 28 Dec 2012 19:21 #4332
by Joshua
Replied by Joshua on topic blade 120sr config?
i can upload a config with throttle hold, flite modes and with different dualrate/expo with mix and RUDD/DR switches.
Here we go:
Throttle hold with Gear switch.
DR/Expo for ELE, AIL with MIX 0/1/2 switch
DR/Expo for RUD with RUD D/R switch
Timer stop on "Hold"
Throttle curve on FMODE0-FMODE2
(Blade120.bmp is from this forum)
ciao, Bernd
Here we go:
ciao, Bernd
Last edit: 28 Dec 2012 19:21 by Joshua. Reason: Upload files
- quikster
28 Dec 2012 19:32 #4336
by quikster
awesome, thanks I got it now. still learning the setup for deviationsbstnp wrote:
Done.
Time to create page: 0.414 seconds
Model Configs
- blade 120sr config?
