V500D01 DEVO
- Hexperience
21 Mar 2013 03:20 - 21 Mar 2013 03:21 #7942
by Hexperience
V500D01 DEVO was created by Hexperience
This is for the V500D01 with 2702v-D gyro RX.
**** This is from a DEVO 12 ****
You may need to edit the switches.
(This is a good test to see how it translates to other TX's)
Flight mode switch is for both throttle and pitch curves.
F0 - Normal
F1 - Full pitch, V throttle curve
F2 - Full pitch, almost straight throttle line
AIL and ELE rates are on the MIX switch, 60,80,100 rates. 10% expo on all, Walkera manual says 45%... edit as you like.
RUD rates 75, 100 on RUD D/R switch.
Throttle hold on HOLD switch.
Gyro on Gear switch, +65%, -65% with Gyro TRIM on the Left trim.
Also note I have a fixed ID, you may want to clear it.
F0 - Normal
Last edit: 21 Mar 2013 03:21 by Hexperience.
- Hexperience
30 Apr 2013 21:30 #9420
by Hexperience
Replied by Hexperience on topic V500D01 DEVO
By the way, to clear the fixed ID on a 2702v-d you need to power up the RX while you have the GEAR signal pin grounded. I.E. Top pin to bottom pin type bind plug on the gear channel. Power it up, it will flash slow. Then power down, remove the plug and power it up while the TX is binding.
Cheers
Cheers
Time to create page: 0.072 seconds
Model Configs
- V500D01 DEVO
