Walkera Quads - Standard Settings
- Tom Z
02 Jun 2014 03:15 - 02 Jun 2014 03:55 #23843
by Tom Z
My post #23839 is for the Devo 7E without the switch mod. That is what you should be using. deviationtx.com/forum/model-configs/1688...ndard-settings#23839
You shouldn't have to fly your ladybird in 3D mode only.
It would help if you exported the model you are using in your transmitter and posted it here. This way the model can be checked.
Replied by Tom Z on topic Walkera Quads - Standard Settings
Torch wrote: Tanks Tom but i didnt do switch mod so i cant use this. Will have to fly my ladybird in 3D mode only.
Last edit: 02 Jun 2014 03:55 by Tom Z.
- Torch
02 Jun 2014 15:14 - 02 Jun 2014 15:14 #23848
by Torch
Replied by Torch on topic Walkera Quads - Standard Settings
I see what Happen. I have to remove your [Channel7]settings from your sample model13.ini fle with [Channel7] that you provided for Devo 7E
[channel7]
template=complex
[mixer]
src=Ch7
dest=Ch7
scalar=-34
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
I will try copy/past this using Notepad ++ and redo it this week.
[channel7]
template=complex
[mixer]
src=Ch7
dest=Ch7
scalar=-34
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
Last edit: 02 Jun 2014 15:14 by Torch.
- Tom Z
02 Jun 2014 15:29 - 02 Jun 2014 17:32 #23849
by Tom Z
Here is my model I just converted for the Devo 7E only. This way you don't need to do anything to my other model (model13) to get it to work for the Devo 7E. Rename this model, install it, and fly it.
I checked this model in the Devo 7E emulator and everything is working correctly.
Model for the Devo 7E and Deviation Firmware v4.
This model has the following settings for Channel 7.
Normal/3D modes are controlled on Channel 7 by the Scalar Value (-34 / 66).
FMOD switch selects Normal and 3D modes.
6 axis mode - Red light on Ladybird
3 axis mode - Green light on Ladybird
[channel7]
template=complex
[mixer]
src=Ch7
dest=Ch7
scalar=-34
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
[channel7]
template=complex
[mixer]
src=Ch7
dest=Ch7
scalar=-34
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
Last edit: 02 Jun 2014 17:32 by Tom Z.
- Torch
02 Jun 2014 17:33 #23853
by Torch
Thanks Alot Tom!
- unknown
26 Jan 2015 21:13 #28053
by unknown
Replied by unknown on topic Walkera Quads - Standard Settings
its possible to use mentioned model configs for QR Y100 HexaCopter?
- wayp55
26 May 2015 10:18 - 26 May 2015 10:23 #32997
by wayp55
Replied by wayp55 on topic Walkera Quads - Standard Settings
Hello, I had 2 ladybird v1 and now v2. With same values, (I copy model 13 in 14) V1 flght perfect, but V2 is impossible to control. V2 is new, and with same configuration, what can I do? Problem could be because V2 is only 3 axis model when V1 is 6axis?
edit. I use devo10 with deviationx 4.0.1
In V1 model led is red, in V2 led is green
Last edit: 26 May 2015 10:23 by wayp55.
Time to create page: 0.210 seconds
Model Configs
- Walkera Quads - Standard Settings
