Trex 500 FBL & Mini Vbar Config, please help...
- evo165
04 Jul 2013 15:13 #11877
by evo165
Trex 500 FBL & Mini Vbar Config, please help... was created by evo165
Hi to all brothers,
I am be getting a good deal of Trex 500 with Mini Vbar from my friend. I can't seem to find any good and suitable config for the above set-up.
Can anyone please help and give me a suitable config?
This is my very FIRST BIG heli... I need a suitable config... I am not expert and it is still pretty new with heli and deviation program..
- Hexperience
04 Jul 2013 15:31 #11881
by Hexperience
Replied by Hexperience on topic Trex 500 FBL & Mini Vbar Config, please help...
What receiver will you be using?
- evo165
05 Jul 2013 00:57 #11919
by evo165
Replied by evo165 on topic Trex 500 FBL & Mini Vbar Config, please help...
Hi sir, I will be using Rx 802 with Devo 10 Deviation v3
Is there any better or suitable Rx for my application?
Looking forward hearing from you soon. Thank you.
- evo165
05 Jul 2013 14:13 #11951
by evo165
Guys, please enlighten if you have any info and tips for the set-up...
- clearprop88
05 Jul 2013 15:56 #11954
by clearprop88
Replied by clearprop88 on topic Trex 500 FBL & Mini Vbar Config, please help...
Just use the helicopter template, and use the Vbar SW to set it up.
- Hexperience
05 Jul 2013 20:33 #11980
by Hexperience
- evo165
06 Jul 2013 08:47 #12008
by evo165
Bro clearprop, which are the correct proper template for FBL Trex 500?
Bro Hex, the link you posted help me to understand more how FBL system work.
I understand that I will be using Devo Rx802 receiver with the Mini Vbar gyro to fly the Trex500.
Basically i can set up a new Heli model with "NO" mixed thingy on all the channels?
If only there is a similar template that is suitable to let me run my set-up.
- buckp50
10 Jul 2013 00:35 #12155
by buckp50
Replied by buckp50 on topic Trex 500 FBL & Mini Vbar Config, please help...
Load a new model.
Choose HELI for model type
Select Swashtype to NONE
receiver type to DEVO
Set your mixers up however you like them
Then you need to run your Vbar setup
Hope this helps.I have a Trex 500 with a Robird and it flies great.
- evo165
12 Jul 2013 02:58 #12202
by evo165
Hi sir, created the model file is straight forward enough. Do you have any tips or advice on the value to set on throttle curve and pitch curve?
Time to create page: 0.132 seconds
Model Configs
- Trex 500 FBL & Mini Vbar Config, please help...
