Looking for Buddy box config for Master CP/Devo7E
24 Jul 2013 16:34 #12475 by Xermalk
Hi
Does anyone have buddy box config files for a master cp and 2 Devo 7E's ?
Well, as long as its for a walkera heli i could change the rest.
24 Aug 2013 01:09 #13190 by dawsonmobley
Replied by dawsonmobley on topic Looking for Buddy box config for Master CP/Devo7E
Unless it was added to the latest version of deviation, buddyboxing is not supported.
24 Aug 2013 03:53 - 24 Aug 2013 16:49 #13194 by sbstnp
Not sure when PPM made it in, but you can buddybox with the nightlies.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 24 Aug 2013 16:49 by sbstnp.
  • rbe2012
  • rbe2012's Avatar
24 Aug 2013 09:56 #13198 by rbe2012
It was implemented after 3.0.0 was released, but works as a charm in the nigthlies.
24 Aug 2013 22:39 #13241 by dawsonmobley
rbe2012 wrote: It was implemented after 3.0.0 was released, but works as a charm in the nigthlies.
Really? thats great!
SO what do I need to do to get it to work? is there a step by step somewhere? I just put 3.0 on my 8s but I'm not clear on how nightlys work?
  • rbe2012
  • rbe2012's Avatar
25 Aug 2013 06:07 #13249 by rbe2012
rbe2012 wrote: On the trainee's tx you set the protocol to PPM out, on the trainer's tx you set PPM in to "Channel", assign the channels (1:1 if you use the same model.ini) and define a trainer switch (don't know which way it works: active means trainee or trainer has control?).
There is another thread about PPM input where you can find further information: www.deviationtx.com/forum/7-development/...gram?start=100#10845
Please look here: http://www.deviationtx.com/forum/6-general-discussions/2114-how-to-setup-double-command#13150 .
27 Aug 2013 03:23 #13332 by dawsonmobley
Thanks for the link, I posted a question about it in the thread you linked.
Time to create page: 0.509 seconds
