Devo 7e models
25 Nov 2014 05:27 #26565 by SLMcc
Replied by SLMcc on topic Devo 7e models
Thanks. I put the Proto X .ini on my 8S and it bound right up. :cheer:
15 Jan 2015 01:30 #27694 by lmbull
Replied by lmbull on topic Devo 7e models
Any one have an ini for wltoys v988?
20 Jan 2015 19:28 #27896 by NanoQXguy
Replied by NanoQXguy on topic Devo 7e models
I have been able to bind my J Perkins Twister Quad AKA WL Toys V949 to my Devo 7E. I know this is a long shot as it's an older model but does anyone have a model ini file for this quad
thanks
Steve
29 Jan 2015 00:05 #28189 by fox
Replied by fox on topic Devo 7e models
Looking for the new hcp100s model !! U_U
29 Jan 2015 16:09 #28208 by pmc
Replied by pmc on topic Devo 7e models
hi
Does anybody have the ini for the wl toys v977 for the devo 7e.
thanks.
i saw this on the net .Would it work.
name=V977
mixermode=Advanced
[radio]
protocol=KN
num_channels=8
tx_power=150mW
[protocol_opts]
Re-bind=Yes
1Mbps=No
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
curvetype=expo
points=25,25
[channel2]
subtrim=170
template=simple
[mixer]
src=AIL
dest=Ch2
scalar=90
curvetype=expo
points=10,10
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
curvetype=expo
points=10,10
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=65
curvetype=expo
points=0,0
[channel8]
template=simple
[mixer]
src=AIL DR1
dest=Ch8
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
[timer1]
type=countdown
src=THR
time=360
[timer2]
src=THR
[datalog]
switch=None
rate=1 sec
[safety]
[gui-128×64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
01 Feb 2015 04:39 - 01 Feb 2015 04:39 #28312 by fox
here two files .ini of my devo for v977 and HCP100s
File Attachment:
File Name: v977.ini
File Size:4 KB
File Attachment:
File Name: HCP100s.ini
File Size:4 KB
regards
Last edit: 01 Feb 2015 04:39 by fox.
01 Feb 2015 07:12 #28314 by jlk69
Replied by jlk69 on topic Devo 7e models
Try this file. It is for the v959 but should work for v949.
jlk69 wrote: Once you have flashed with Deviation and installed the proper module. Try this config file.
File Attachment:
File Name: model12.ini
File Size:12 KB
This file is for a 7e with two extra 3 way switches installed. The flip button is fmode 1 and TH is hold 1. Lights are also programed to a switch (can't remember the exact switch). The other functions are not programed because this is a v929 airframe with a v959 FC so no special attachments (Camera, bubble etc.)
25 Feb 2015 04:38 #29087 by mcm.repairs
Replied by mcm.repairs on topic Devo 7e models
does anyone have a model for Syma X5C-1 I am having problems finding to my Devo 7e
25 Feb 2015 04:39 #29088 by mcm.repairs
25 Feb 2015 06:40 #29091 by Durete
25 Feb 2015 12:58 #29096 by mcm.repairs
This model zip is a little different from the one I used. Does it bind automatically or do I have to change any settings first?
25 Feb 2015 13:28 #29097 by Durete
Replied by Durete on topic Devo 7e models
The SymaX protocol uses auto bind, so first connect the battery at quadcopter and after some seconds start the TX. They will bind automatically.
The Unique ID at this protocol, is used to randomize the TX address and channels used.
Be aware, from 15-2-14 nightly, the SymaX protocol changed to reduce code size and now is allways at high rates. We need to simulate rates with the mixer.
My config file have this changes.
25 Feb 2015 13:35 #29099 by mcm.repairs
Thanks Durete. Can you send me your config files? I'd there a way to set up the camera and high low rates to different switch?
25 Feb 2015 13:42 #29100 by Durete
My config file is attached the post I linked before :)
www.deviationtx.com/forum/3-feedback-que...vo-7e?start=20#28728
25 Feb 2015 16:26 #29107 by mcm.repairs
I used the x11c and x11c-1 and syma still will not bind. do I need to delete the fixed ID or which receiver protocol do I use. Can not figure what I'm doing wrong to keep it from binding.
25 Feb 2015 17:22 #29111 by mcm.repairs
after doing some reading research, do I have to instal the hardware shown in the previous threads to make this work
25 Feb 2015 17:39 #29112 by Durete
Off course. You need an nRF24L01 module installed at your Devo TX :)
21 Mar 2015 19:02 #30005 by djbachelor
Replied by djbachelor on topic Devo 7e models
Should this work with the X11 as well as the X11c? I am using a Devo 10 and installed both the A7105 and nRF24L01 modules... I have been flying my X1, so I know the A7105 works. (New to all this--it took me a while to get to that point.)
The X11 model config shows "bind" next to the V202 protocol, so it appears to be enabled.
I have installed the latest nightly using dfuse; my tx shows 4.0.1-e1a3b14 at startup. I then copied all the nightly files over via USB.
Can't get it to bind to the X11. Here are my hardware.ini, tx.ini and model files. Can anybody tell me what I'm missing here?
Thanks to this awesome community for the support.
21 Mar 2015 23:17 #30019 by Durete
djbachelor wrote: Should this work with the X11 as well as the X11c? I am using a Devo 10 and installed both the A7105 and nRF24L01 modules... I have been flying my X1, so I know the A7105 works. (New to all this--it took me a while to get to that point.)
You are trying to bind with your X11 using V202 protocol.
You need to change your model file and bind with SymaX protocol.
I attached my Syma X11 model file and model icon.
22 Mar 2015 00:20 #30024 by djbachelor
Perfect, that did the trick! Thank you!
Which switch typically engages flips? I tried everything on my X1 and could get it to work. (My X11 has a bum motor, so I can't actually try it at the moment.)
Thanks again.
Time to create page: 0.187 seconds
