HK Assault 450 devo 10 config
- auceto
01 Dec 2014 22:20 - 01 Dec 2014 22:24 #26718
by auceto
HK Assault 450 devo 10 config was created by auceto
Hi at all....friends
I just buyed this heli from HobbyKing...I've binded the heli with my dx6i and all it's ok...
Now with my devo 10 and 4.0.1 firmware I've this problem:
I bind the heli in DSM2 protocol (the hely has an orange r100 satellite in DSM2) but the motor do not run...I do the same after reversed the throttle and after a lot of time the motors start to max and do not stop with hold...I have to pull out the battery.
Naturally I set the curves in the various channels and set the failsafe to -100 in throttle channel and the switch to set the motor to -100 value)...
What do I wrong?
Can anyone help me to configure the devo for this hely?
thanks a lot
What do I wrong?
thanks a lot
Last edit: 01 Dec 2014 22:24 by auceto.
- auceto
07 Jan 2015 21:35 #27557
by auceto
Replied by auceto on topic HK Assault 450 devo 10 config
At the end I win and this is the model ini for Assault 450 equipped with Specktrum Ar6210 RX and its satellite
- Gzus11
13 Feb 2016 00:25 #43069
by Gzus11
Replied by Gzus11 on topic HK Assault 450 devo 10 config
Hello, I'm setting up this model using your info here, can you explain the purpose for second rudder on channel5?
- TomPeer
14 Feb 2016 10:42 - 14 Feb 2016 10:43 #43107
by TomPeer
Replied by TomPeer on topic HK Assault 450 devo 10 config
when the curvetype=fixed, the source is ignored. it does not matter what is written there. ch 5 is probably a switch to set gear rate.
Last edit: 14 Feb 2016 10:43 by TomPeer.
Time to create page: 0.218 seconds
Model Configs
- HK Assault 450 devo 10 config
