7e - Flureon H101 with silverxxx firmware
30 May 2016 23:21 - 31 May 2016 06:31 #49598 by HappyHarry
7e - Flureon H101 with silverxxx firmware was created by HappyHarry
this is for using with a flureon h101 that has been flashed with silverxxx's great replacement firmware, the model file is setup to cater for a 7e with just the stock switches, and the quad is setup as a 3d/inverted trainer with both the 'native inverted mode' and '3d throttle' defines enabled, and level/acro mode set to ch_flip in the firmware. it works as such
fmode0 = only positive throttle, and the throttle range is only from mid stick upwards
fmode1 = full positive and negative throttle with 0 throttle in the middle.
I set it this way so that the positive throttle range is the same in both modes, it will be better for the muscle memory and also mimics a cp heli setup
throttle trim+ (up) = toggles between level/acro mode
hold0 = nothing
hold1 = throttle hold
hold1 will kill the throttle no matter what flight mode or stick position.
Last edit: 31 May 2016 06:31 by HappyHarry.
31 May 2016 16:42 #49658 by victzh
Replied by victzh on topic 7e - Flureon H101 with silverxxx firmware
Thanks a lot! I plan to apply silver's firmware to my H101, now that we have a config for it it should be even easier.
31 May 2016 19:37 #49673 by HappyHarry
Replied by HappyHarry on topic 7e - Flureon H101 with silverxxx firmware
no problem victzh, it's one of the few ways i can give back to the community :)
due to a suggestion on rcgroups i've also attached my config.h from the firmware so that the channels that are mapped work as set on the tx, inside the zip i've also added a compiled firmware for someone who just wants to flash and fly, as well as an icon for the H101
30 Aug 2016 13:12 #53278 by DELGADO
Replied by DELGADO on topic 7e - Flureon H101 with silverxxx firmware
Hi can I use in h8 3D?
or can you splain how are yo do this?
because I´d like fly with this stick configuration
30 Aug 2016 20:55 #53299 by HappyHarry
this will work for the h8s 3d, but only if it has been flashed with silverxxx's firmware bud
31 Aug 2016 07:30 #53319 by DELGADO
Ok thanks a lot
20 Feb 2017 09:33 #59361 by puiumeu
Replied by puiumeu on topic 7e - Flureon H101 with silverxxx firmware
HappyHarry wrote: this is for using with a flureon h101 that has been flashed with silverxxx's great replacement firmware, the model file is setup to cater for a 7e with just the stock switches, and the quad is setup as a 3d/inverted trainer with both the 'native inverted mode' and '3d throttle' defines enabled, and level/acro mode set to ch_flip in the firmware. it works as such
hold0 = nothing
What are the differences between a 7e and a 10 config. I would love to use these features on my 10. I do not remember seeing such a complete solution.
Time to create page: 0.516 seconds
