Walkera QR X350PRO
19 Jun 2016 17:19 - 23 Jun 2016 09:12 #50810 by mindo
Walkera QR X350PRO was created by mindo
here ini file used for my Walkera QR X350 PRO
FMOD0= normal
FMOD1=Simple mode (OIC)
FMOD2=Super Simple mode (OIC)
MIX0=normal
MIX1= Position Hold
MIX2=Return to launch
MIX2+AILDR1=AUTO (Executing Mission)
GEAR1=Panic Button (motors stop)
AUX4 knob (CH6)= Gimbal tilt control
Enjoy!
__________________________________
name=QR350PRO
mixermode=Advanced
type=plane
[radio]
protocol=DEVO
num_channels=11
tx_power=150mW
[protocol_opts]
Telemetry=On
[channel1]
template=expo_dr
[mixer]
src=ELE
dest=Ch1
[mixer]
src=ELE
dest=Ch1
switch=ELE DR1
scalar=60
[channel2]
template=complex
[mixer]
src=AIL
dest=Ch2
[mixer]
src=AIL
dest=Ch2
switch=AIL DR1
scalar=60
[channel3]
safetysw=GEAR1
safetyval=-100
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
switch=RUD DR1
scalar=60
[channel5]
template=complex
[mixer]
src=!MIX0
dest=Ch5
switch=MIX0
scalar=-48
offset=-53
curvetype=zero/max
points=0
[mixer]
src=AIL DR0
dest=Ch5
switch=MIX1
scalar=20
offset=-20
usetrim=0
curvetype=zero/max
points=0
[mixer]
src=AIL DR0
dest=Ch5
switch=MIX2
scalar=55
offset=45
usetrim=0
curvetype=zero/max
points=0
[channel6]
template=simple
[mixer]
src=AUX4
dest=Ch6
scalar=-100
[channel7]
template=complex
[mixer]
src=FMODE0
dest=Ch7
[mixer]
src=AIL
dest=Ch7
switch=FMODE1
scalar=0
usetrim=0
curvetype=fixed
[channel8]
template=simple
[mixer]
src=AUX5
dest=Ch8
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=5
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=5
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=5
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=5
[trim5]
src=Virt2
pos=TRIM_R+
step=193
value=-100,0,0
[trim6]
src=Virt1
pos=TRIM_L+
step=193
value=-100,0,0
[timer1]
src=THR
resetsrc=Virt1
[timer2]
type=countdown
src=THR
resetsrc=Virt2
time=900
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,131,0,AIL DR
Toggle=31,10,0,212,202,MIX
TxPower=102,7
Toggle=40,10,0,193,194,FMODE
quickpage1=Telemetry monitor
Last edit: 23 Jun 2016 09:12 by mindo.
21 Jul 2016 18:45 #51962 by Mick1113
Replied by Mick1113 on topic Walkera QR X350PRO
05 Aug 2016 18:46 #52477 by nelsonlee
Replied by nelsonlee on topic Walkera QR X350PRO
mindo wrote: Hi,
FMOD0= normal
MIX0=normal
MIX1= Position Hold
Enjoy!
name=QR350PRO
mixermode=Advanced
type=plane
[radio]
protocol=DEVO
num_channels=11
tx_power=150mW
[protocol_opts]
Telemetry=On
[channel1]
template=expo_dr
[mixer]
src=ELE
dest=Ch1
[mixer]
src=ELE
dest=Ch1
switch=ELE DR1
scalar=60
[channel2]
template=complex
[mixer]
src=AIL
dest=Ch2
[mixer]
src=AIL
dest=Ch2
switch=AIL DR1
scalar=60
[channel3]
safetysw=GEAR1
safetyval=-100
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
switch=RUD DR1
scalar=60
[channel5]
template=complex
[mixer]
src=!MIX0
dest=Ch5
switch=MIX0
scalar=-48
offset=-53
curvetype=zero/max
points=0
[mixer]
src=AIL DR0
dest=Ch5
switch=MIX1
scalar=20
offset=-20
usetrim=0
curvetype=zero/max
points=0
[mixer]
src=AIL DR0
dest=Ch5
switch=MIX2
scalar=55
offset=45
usetrim=0
curvetype=zero/max
points=0
[channel6]
template=simple
[mixer]
src=AUX4
dest=Ch6
scalar=-100
[channel7]
template=complex
[mixer]
src=FMODE0
dest=Ch7
[mixer]
src=AIL
dest=Ch7
switch=FMODE1
scalar=0
usetrim=0
curvetype=fixed
[channel8]
template=simple
[mixer]
src=AUX5
dest=Ch8
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=5
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=5
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=5
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=5
[trim5]
src=Virt2
pos=TRIM_R+
step=193
value=-100,0,0
[trim6]
src=Virt1
pos=TRIM_L+
step=193
value=-100,0,0
[timer1]
src=THR
resetsrc=Virt1
[timer2]
type=countdown
src=THR
resetsrc=Virt2
time=900
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
Hi, may i know this setting is for Devo 7E or Devo 10 Deviation firmware?
Regards,
Nelson
09 Aug 2016 05:36 #52604 by Ryno
Replied by Ryno on topic Walkera QR X350PRO
Mate unless it's a modded Devo 7E the switch allocation is for Devo 10.
I am currently using it for Devo10 so thanks to 'mindo' for posting. I do have some questions of my own to post.
Cheers
Ryno
09 Aug 2016 05:45 #52605 by Ryno
As above, thanks 'mindo' for posting, also thanks to all who have assisted with Deviation, really appreciate your work for those of us with less functioning brain matter :P
I am surprised there is not more about the QRX 350 PRO.
I put Deviation(5.0) on Devo10 to run DSM/DSMX for race quads and I love it over going the ever popular Taranis route.
Couple of Questions re this config...
1, For the life of me I cannot get G2D gimbal control to work, it worked fine pre deviation but now nada checked plugged into right ch etc. but no tilt control from Aux knob
2, Any ideas on how to get Telemetry to work using Devo Telem module? again this worked pre Deviation
3, I have bound to the stock RX701 Rx but when I turn transmitter on it says something like rebinding with Rx?? possibly fixed ID I have not checked that yet?
Any assistance much appreciated.
Cheers
Ryno
16 Aug 2016 19:28 - 16 Aug 2016 19:32 #52826 by mindo
Replied by mindo on topic Walkera QR X350PRO
Very strage your problem about gimbal. I use g2d from walkera and it's fine. Did you check correct pins of tre three wires connecting to gimbal unit?
About binding, I do not use fixediD try to change to automatic assignement
Last edit: 16 Aug 2016 19:32 by mindo.
16 Aug 2016 19:31 - 16 Aug 2016 19:33 #52827 by mindo
A note if you use mission planner with qr350. There is a sw bug in mission planner and flight modes 3 and 4 goes always to alt hold regardless of what you have configured so check your settings and verify
Last edit: 16 Aug 2016 19:33 by mindo.
17 Aug 2016 03:52 #52832 by Ryno
Hi Mindo
Appreciate the reply. Re Gimbal yeah I checked on correct pins, I am sure the gimbal is still OK as of last time had it hooked up and all good. Still will have another look ad re recheck, might even dig out servo tester and hook up to test gimbal.
Will check re Auto assignment Ta
I think I noticed Alt Hold highlighting in mission planner and thinking it was not right. Again will have more of a play, bit rusty on this now need to get my eye back in.
Cheers
Ryno
Ryan
17 Aug 2016 07:30 - 17 Aug 2016 07:38 #52833 by mindo
Ryno wrote: Hi Mindo
Cheers
Ryno
Ryan
Let's try to calibrate all knobs and sticks too!
Last edit: 17 Aug 2016 07:38 by mindo.
