Need setting walkera mini cp
03 Oct 2012 14:44 #1951 by teremok
Need setting walkera mini cp was created by teremok
Please people do adjust to walkera mini cp will be very grateful! Himself but tried not to get! :(
03 Oct 2012 15:01 #1953 by FDR
Replied by FDR on topic Need setting walkera mini cp
I think you can try one of the uploaded GeniusCP configs as a starting point.
They shouldn't differ too much...
04 Oct 2012 20:15 #1993 by yohann
Replied by yohann on topic Need setting walkera mini cp
+1 need les réglages pour le mini cp, un mode normal et un mode 3d en iddle up pour de la bonne 3d!
merci d'avance
08 Oct 2012 19:50 #2052 by Helibasher
Replied by Helibasher on topic Need setting walkera mini cp
ive tried the config from the Genius CP but the Rx ist blinking Green/Red which means that the Gyro is disabled.
Anyone has a running config for the Mini CP or cann tell me how to enable the Gyro?
08 Oct 2012 19:56 - 08 Oct 2012 19:58 #2054 by rototophe
Replied by rototophe on topic Need setting walkera mini cp
Gyro sensitivity should be on channel 5.
Set a flat curve on channel 5 with value around 50, should be getting you started.
You can adjust the value to taste and even set two different values assigned to a switch on the TX to toggle gyro gain ....
Last edit: 08 Oct 2012 19:58 by rototophe.
08 Oct 2012 20:04 #2056 by FDR
Are you sure?
I think gyro is channel 7 if the number of channels is more then 6, i.e. in deviation from v1.1.0 always...
08 Oct 2012 20:10 - 08 Oct 2012 20:12 #2057 by rototophe
FDR wrote: Are you sure?
Right. My answer is valid only if you use 6 channels, like for example if you set up your model using the 6 channels heli template. I fly a solo Pro 125 using the 6 channels template, gyro on channel 5 with a dual rate switch. Should work as well for mini CP.
Gyro will "jump" to channel 7 (I believe) if you use 8 channels.
Last edit: 08 Oct 2012 20:12 by rototophe.
08 Oct 2012 21:00 #2058 by Helibasher
I only have a Devo6s, setting a flat on channel5 wont change anything. The Rx ist still blinking red/green.
08 Oct 2012 21:19 #2061 by rototophe
Did you try varying the value up and down for the flat curve to see if it changes anything?
08 Oct 2012 21:24 #2062 by Helibasher
Yes, i tried 50 and 100. Still having the blinking after binding.
08 Oct 2012 21:27 #2063 by rototophe
Wierd.
When you say it is blinking red/green, is it like 6 axis / 3 axis gyro like on the ladybird? I mean the color code?
08 Oct 2012 21:35 #2065 by Helibasher
I dont have a Ladybird, so i dont know what its blinking.
Whats the difference between 6 axis and 3 axis gyro? Its only blinks one red and one green.
08 Oct 2012 22:31 #2068 by Helibasher
Got it, the Gyro was configured on Channel7. So it does not work with my Devo6s. I changed the Gyro now to Channel5 and now it works.
08 Oct 2012 23:23 #2071 by rototophe
Good! Glad you got it figured out :)
09 Oct 2012 09:08 #2090 by digitracer
Replied by digitracer on topic Need setting walkera mini cp
Helibasher wrote: Got it, the Gyro was configured on Channel7. So it does not work with my Devo6s. I changed the Gyro now to Channel5 and now it works.
Just for my understanding: how and where did you configure your gyro to channel5?
I have a Genius CP with Devo6 bundled using the config file from FDR where gyro is set to channel7. Though I am wondering whether gyro is set to channel5 or 7 by default.
09 Oct 2012 09:19 #2091 by FDR
It depends on the number of channels.
For a 6 or less (i.e. 5) channel transmitter the gyro is on chammel 5, for a 7 or more channel transmitter it is on channel 7 (as is in my Genius config, switchable by the MIX switch).
However if I remember well, PB changed the code, so deviation always sends at least 8 channel (i.e. the gyro should be always on ch7), but the previous comments made me unsure about that. I had to change my Ladybird config back then, because it had 5 channels configured (gyro was on ch5), and I had to change it to a 7 channel config to move the gyro to ch7.
I have to recheck that again...
03 Jan 2014 03:25 #17803 by yidc
Replied by yidc on topic Need setting walkera mini cp
So, for a 7 channel config, gyro is configured at ch7
while ch5 is NO USE? B)
03 Jan 2014 07:57 #17821 by FDR
Yep.
Time to create page: 0.403 seconds
