Request for Devo8 Models for any 450 helicopter
13 Jul 2016 08:44 #51599 by Fernando
Hi everyone,
Just for testing purposes and to be sure the models I make by myself are well configured, I ask for a 450 model.ini file.
I really need it because I find some issues while flying and I think there is something wrong on my configs. Just if it were important, my 450 is a Tarot Pro and I fly with a Vbar FBL.
Please, I just want to load the model on my Devo and check its parameters with my own. It will be really helpful.
Thank you for your help.
Regards.
13 Jul 2016 16:14 #51604 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Request for Devo8 Models for any 450 helicopter
Ok, which RX?
13 Jul 2016 17:38 - 13 Jul 2016 17:39 #51615 by Fernando
My RX is a Spektrum Satellite. I bind with a DSM2 receiver.
Last edit: 13 Jul 2016 17:39 by Fernando.
13 Jul 2016 19:17 #51618 by -=Hubi-Dirk=-
Try the attached .ini as an example.
1. THR 1:1 for spinning up, FMODE 1 & 2 = Fixed for Governor Mode
2. AIL & ELEV: Less DR and more EXPO swiched by AIL and ELV DR Switches
3 RUD = Simple 1:1
4. Ch6 as Pitch: Flat curve fpr spinning up, FMODE 1 & 2 = Full pos and neg Pitch
13 Jul 2016 19:24 - 13 Jul 2016 19:40 #51619 by -=Hubi-Dirk=-
If you dont use Governor at Throttle, the attached .ini has differnt V-Curves at FMODE 1 & 2
Last edit: 13 Jul 2016 19:40 by -=Hubi-Dirk=-.
14 Jul 2016 06:42 #51631 by Fernando
Thank you -=Hubi-Dirk=-, I will test it and will post the results. I do not fly with governor but I were thinking to enable it soon, so very useful as well. :)
31 Jul 2016 15:17 #52322 by Fernando
-=Hubi-Dirk=- wrote: If you dont use Governor at Throttle, the attached .ini has differnt V-Curves at FMODE 1 & 2
Hi!, I loaded at last.
I have seen your config and see that your GEAR channel (5) you have NONE. How do you set the tail gain?
I use the switch GEAR to switch between head lock (around 40, variable) to avoid fishtail, and -100 to unset the heading lock.
Time to create page: 0.379 seconds
